Author: Subject: 4age shortern sump
rabbit
posted on 3/1/10 at 07:48 AM Reply With Quote
4age shortern sump
does anyone have or know of a 4age shortern sump 07743982682 thanks
Werner Van Loock
posted on 3/1/10 at 07:51 AM Reply With Quote
Raw can supply them,
like this one:
http://www.jpsc-online.co.uk/viewtopic.php?f=6&t=249
http://www.clubstylus.be
bimbleuk
posted on 3/1/10 at 09:30 AM Reply With Quote
like this one:
You won't get a sump like that from RAW at the price that one went for!
The one below was the how I wanted RAW to modify the standard sump to provide a cheaper option for me.
The original sump sides provide baffling inside and a lip is added to the inside of the middle opening to help prevent the oil escaping. I used my sump with three differnet engine configurations with no issue.
Shortened sump
Shortened sump
COREdevelopments
posted on 3/1/10 at 08:35 PM Reply With Quote
I have chopped out about an inch or so from the bottom of my sump. It meant i lost approx half litre from the sump. I now use an accusump and keep the oil level just above maximum. I didnt add any extra wings on the side as i had the accusump to hold the extra oil.
Rob
rabbit
posted on 4/1/10 at 06:16 AM Reply With Quote
4age sump
thanks to all i know raw sump is over £200 . just seeing if anyone had one forsale , like the wing sump have someone local who a good welder .
bimbleuk
posted on 4/1/10 at 11:31 AM Reply With Quote
The one I pictured above is a lot less than £200 from RAW. At least it was when I had mine modified.
If you know a decent welder then just copy my design as its based on reading a few articles about sumps. Add gated baffles if you want to improve the design. Maybe even raise the factory horizontal baffle plate to trap more oil below.
rabbit
posted on 7/1/10 at 06:43 AM Reply With Quote
sump
hi guys thanks for your info, think i located one off westfield site like steel wing one with oil pickup
