Major Stare
posted on 8/1/10 at 04:42 PM |
New clutch fitted and engine stalls when gear selected
New Barnet clutch fitted to 2003 R1.
Warmed engine up, started to hear a slight screaching. Blipped clutch and went, engaged first............. engine staled.
Couldnt get out of gear/neutral, so rocked car and eventually got neutral.
Any idea's?
I pressume the clutch needs adjusting?
Jon "FISH"
spdpug98
posted on 8/1/10 at 05:33 PM |
Sounds like when you put the cover back on, the clutch bar (for want of a better/the correct word) was engaged too far, I had the other extreme when I
did mine and couldn't engage to clutch, loosened to cover and adjusted the bar
But yours sounds like you just need to adjust the clutch cable
[Edited on 8/1/10 by spdpug98]
My Blog: http://spdpug98.wordpress.com/
progers
posted on 8/1/10 at 05:52 PM |
Sounds like your new stiffer clutch needs a bit more pull before the clutch plates are separated. Maybe your clutch cable is stretching and/or needs
to be tightened to give more throw at clutch lever.
- Paul
phoenix42
posted on 8/1/10 at 06:32 PM |
hi there, sounds like your problem is adjustment only, i had a similar problem with my 5pw when upgrading to a barnett. i,m only just down the road
from you and be glad to help if you need any.cheers paul.
Major Stare
posted on 8/1/10 at 08:36 PM |
Cheers guys,
Paul......... you have U2U
Jon "FISH"
progers
posted on 9/1/10 at 03:02 PM |
quote: Originally posted by Major Stare
Cheers guys,
Hi - no messages in my U2U inbox!
Major Stare
posted on 9/1/10 at 09:44 PM |
Cheers guys,
The other Paul
Jon "FISH"
