steveyb
posted on 21/1/10 at 12:41 PM |
v6 type 9 dimensions/ drawing
Has any one got a drawing or measurements of a v6 type 9 gearbox bell housing. i'm looking the dimensions of where it bolts to the engine.
James
posted on 21/1/10 at 04:30 PM |
Where it bolts to the engine is the same as the normal Type 9 if that helps you widen your search at all.
James
- Muhammad Ali
dave r
posted on 21/1/10 at 04:47 PM |
i have a drawing of the spacer thats needed to turn it into a pinto one
have a spare spacer actually if thats what you want it for
dave
MakeEverything
posted on 23/1/10 at 11:33 AM |
James
No its not.
The V6 is a cologne engine, which is a different stud pattern to the sierra CVH.
The V6 Essex is different again i believe so it depends on whether your engine is a 3.0 or 2.8 / 2.9? The 2.8 and 2.9 were the cologne, and the 3.0
was the Essex engine.
I think ive got one in the shed if you want it. It cost me £150. Its all ali and will fit the cologne.
Kindest Regards,
Richard.
snapper
posted on 25/1/10 at 01:13 PM |
What do you need to know?
I have a V6 box in the garage, a V6 bellhousing with it and a V6 Type 9 with spacer and RS2000 bell housing in the car
The bell housing bolt pattern for the 4 cylinder fords is the same from the Crossflow to the Zetec. The V6 uses a different bellhousing bolt pattern
than the 4 cylinder engines but is the same pattern for all V6's from the Essex 3.0L to the Cologne 2.9L.
U2U Dave for a copy of the drawing
I eat to survive
I drink to forget
dave r
posted on 25/1/10 at 04:27 PM |
if they are the same for colongne and essex, why are they listed seperate in burtons ? whats the diff ?
