Author: Subject: Question regarding wheel thread length
alexg1965
posted on 3/5/10 at 06:04 PM Reply With Quote
Does any one have any idea how much thread should be available for the wheel nuts to fit on. I don't seem to have that much (20mm?) with my new wheels and am wondering whether or not to fit longer studs.
Daddylonglegs
posted on 3/5/10 at 06:14 PM Reply With Quote
Originally posted by Daddylonglegs
I'm sure someone more knowledgeable will be along in a moment, but I have always been told that any bolt/stud should always have at least 3 threads showing through the nut.
(Unless they are closed wheel nuts of course )
HTH
[Edited on 3/5/10 by Daddylonglegs]
mad4x4
You need to have about a thread & 1/2 showing once the Wheel and nut is on unless the nut is closed at the end.... However a closed nut may not be allow be allowed at SVA/IVA (can;t remember that one)
Scot's do it better in Kilts.
Daddylonglegs
posted on 3/5/10 at 06:16 PM Reply With Quote
Oh poo! Guess what nuts I'm using
brianthemagical
posted on 3/5/10 at 06:18 PM Reply With Quote
Depending on thread pitch, you want the nut to cover at least the dia of the stud, then the stud will fail not the thread.
All in theory though.
designer
posted on 3/5/10 at 06:37 PM Reply With Quote
1 1/2 to 2 threads must protrude from the nut.
wicket
posted on 3/5/10 at 09:30 PM Reply With Quote
See link in my second posting here for detailed info.
http://www.locostbuilders.co.uk/viewthread.php?tid=53769
alexg1965
posted on 4/5/10 at 06:12 AM Reply With Quote
Thanks all for the info. I too have closed end wheel nuts which passed SVA in 2005. I'll measure up the exposed thread this morning.
