<<  1    2  >>
Author: Subject: need help with gears
CraigJ
posted on 7/1/11 at 08:19 PM Reply With Quote
im looking for 2 identical gears. around 2-3 inch in diameter and about 1 inch wide. I'm wanting to make a small gear box to change drive direction.
A bike engine will be mounted backwards so the drive needs to be changed so i have 6 forward gears and not 6 reverse ones. This is going in a mini so space is tight. One of the gears will be attached to the engine and the second gear will have a sprocket with a chain going to a chain diff.
Any help will be great.
Craig.
dilley
posted on 7/1/11 at 08:26 PM Reply With Quote
Why has the engine got to be installed backwards?
CraigJ
posted on 7/1/11 at 08:29 PM Reply With Quote
because if i install the other way there is no space for the diff as it will need to go directly behind the engine. only other way i can think is to mount the diff above with a chain going up the two coming down to the drive shafts but this is too complicated and time consuming.
snapper
posted on 7/1/11 at 08:37 PM Reply With Quote
MNR or Quaife reverse box would do it.
You can't use any old gears driven at 11000 rpm with 100 ft/lbsgoing through them
I eat to survive
I drink to forget
chunky2772
posted on 7/1/11 at 08:40 PM Reply With Quote
The oil pick up is also at the rear end of most bike egines. Could cause a few problems extending the oil pick up if your not useing a dry sump!
chunky2772
posted on 7/1/11 at 08:44 PM Reply With Quote
Also the gears wouldent last two minutes without a supply of oil to them.
CraigJ
posted on 7/1/11 at 09:02 PM Reply With Quote
oil pick up wont be a problem.
The gears will be in a casing with oil.
Just need a source or the gears/where to look.
They need to be able take the abuse from the engine with out chewing each other up.
liam.mccaffrey
posted on 7/1/11 at 09:13 PM Reply With Quote
maybe butcher a scrap gear box,
or
build a small 2 cog offset box (like a 4x4 transfer box with splash lubrication or even a small circulating pump with an oil cooler if heat is a problem.
HPC Gears are very good for the cogs
Check in the technical section for all manner of info linky
[Edited on 7/1/11 by liam.mccaffrey]
Build Blog
Build Photo Album
chunky2772
posted on 7/1/11 at 09:20 PM Reply With Quote
i have an idea don't laugh! mount the diff upside down this will change direction .you will have to change the oil drain to other side of the diff though. your right wheel will become your left side and your left wheel will become your right.
its an easy fix and save a load of hastle.
[Edited on 7/1/11 by chunky2772]
SPYDER
posted on 7/1/11 at 10:30 PM Reply With Quote
Ha ha ha!
No it won't.
Think about it.
procomp
posted on 7/1/11 at 11:05 PM Reply With Quote
Hi
Type 9 5speed 5th gears maybe.
Cheers Matt
steve m
posted on 8/1/11 at 05:44 AM Reply With Quote
"i have an idea don't laugh! mount the diff upside down this will change direction "
yes this would work
chunky2772
posted on 8/1/11 at 09:17 AM Reply With Quote
Think harder! get a diff turn it upside down with input drive shaft still faceing the same way watch what happens!
Your diff still turns the same direction but you will move backwards i aint jokeing! This is your problem solved you may have to put a little more oil in the diff and change the drain plug but its a much easyer fix. CAN SOMEONE PLEASE TRY THIS AND BACK MY IDEA UP.
adithorp
posted on 8/1/11 at 09:55 AM Reply With Quote
Ha ha ha!
No it won't.
Think about it.
Oh yes it will!
http://jpsc.org.uk/forum/
ReMan
posted on 8/1/11 at 09:56 AM Reply With Quote
NO A CHAIN DIFF WONT WORK UPSIDE DOWN
Not ideal for the helical gears but in our apps acceptable
Edited as the penny has dropped
[Edited on 8/1/11 by ReMan]
blue2cv
posted on 8/1/11 at 09:59 AM Reply With Quote
Diff is to be chain driven, wont matter which way up it is, will still turn same way
blue2cv
posted on 8/1/11 at 10:03 AM Reply With Quote
Look at www.r1manx.com may give some inspiration
SPYDER
posted on 8/1/11 at 01:19 PM Reply With Quote
Its a CHAIN driven diff.
Go and think about it again.
Geoff
blue2cv
posted on 8/1/11 at 01:22 PM Reply With Quote
Do you think the penny will drop Geoff
indykid
posted on 8/1/11 at 01:31 PM Reply With Quote
hahaha
if you don't have a pinion, you can't run it upside down.
surely enough people have done successful mini conversions now that you could follow their example and save the faff of making a box?
i assume you'll be using helical rather than spur gears? a car gearbox would be my first choice if i were to be making a box.
phelpsa
posted on 8/1/11 at 01:32 PM Reply With Quote
Geoff
How about if you mount the chain upside down as well?
chunky2772
posted on 8/1/11 at 02:02 PM Reply With Quote
ha, ha, I love this!
CraigJ
posted on 8/1/11 at 02:44 PM Reply With Quote
Yes it will still be a chain diff and not a normal diff so mounting upside down wont help.
There are kits etc for doing this like from pro-motive but its 3.5k which i dont have.
Will have a look at some gears from a gearbox. see what i can make lol.
NS Dev
posted on 8/1/11 at 08:19 PM Reply With Quote
engine longitudinal, sprocket pointing forwards, direct driving a (normal car, with pinion) diff pointing the "wrong way" and turned upside-down.
This is what we looked at doing on the supercharged Blackbird engined fiat 126 we're building before we went for the current plan:
open chain drives are nasty and I really don't like them! (yes I do say that based on experience! )
[Edited on 8/1/11 by NS Dev]
SPYDER
posted on 8/1/11 at 08:25 PM Reply With Quote
[ tongueincheek] Could you use a Mobius strip chain? Mounted inside out.
Or put the front wheels on the back.
That would work wouldn't it? [/tongueincheek]
On a serious note, something like this maybe....
Found it HERE
<<  1    2  >>
