ned
posted on 1/7/04 at 01:28 PM |
would SPA speedo pass sva?
I want to use the SPA digital speedo which incorporates a switchable odometer. Any idea if this would get through sva ok? What is the specific
requirement in the sva book as I don't have a copy. Is there any rule about the odometer having to be permanently visibile instead of switchable
on the digital display? How do the other digi dashes work?
Thanks,
Ned.
ps link here:
http://www.spa-uk.co.uk/design/speedo.htm
[Edited on 1/7/04 by ned]
beware, I've got yellow skin
timf
posted on 1/7/04 at 01:33 PM |
switchable should be ok
if not how do all the jeeps like mine pass
as the odometer and tripmeter share the same display.
Fifer
posted on 1/7/04 at 03:06 PM |
I agree, it should be OK.
By the way Ned, how the hell do you get on building a car without the SVA manual !. I had to refer to it almost every week over my build ?
How much is the SPA speedo by the way ?
ned
posted on 1/7/04 at 03:15 PM |
I have a pdf document that has some info in it fifer, though it's not to hand.
The cheapest place I've found is stuart taylor who list it at £138, which when most normal type gauges are around £80-100 doesn't seem too
bad when it has the programable timers and is nice and compact.
Ned.
Fifer
posted on 1/7/04 at 03:33 PM |
Dont forget my Nordskog ones, I can do them for 150quid including hall effect sender (just point at propshaft uni joint, no magnets required) +
carraige in UK.
Has 0-60, 1/4 mile, high speed recall etc. (looks better than the SPA one too in my opinion !)
fifer
ned
posted on 1/7/04 at 03:45 PM |
Fifer,
Hadn't forgotten, was looking at them just this morning after your post on 0-60 times. I assume you mean the m9222 speedo? I personally
don't like it i'm afraid as it would clash horribly with the other gauges I plan to use.
Ned.
Fifer
posted on 1/7/04 at 03:49 PM |
fair comment, just checking
timcrasher
posted on 2/7/04 at 06:27 AM |
Ned, I have a Spa digital speedo with switchable odometer, 0-60 timer etc. It's about the same size as a small box of matches.
I passed the SVA test no problem. The tester was impressed how accurate it was, ( 0.2 mph ) under reading at all the speeds tested.
Fifer
posted on 2/7/04 at 08:00 AM |
That would be a fail wouldnt it ?
"0.2 under"
ned
posted on 2/7/04 at 08:26 AM |
timcrasher, thanks for that. I hadn't heard of anyone using one up til now..
Ned.
BMF
posted on 2/7/04 at 03:27 PM |
Ned have a look at this!
Thought you may be interested!
http://www.kitcarmart.co.uk/cgi-bin/suite/classifieds/classifieds.cgi?request=detail&id=10217&category_id=114&sub_id=1080&variable_fil
e=default.variables&group=&set=1&position=1&total_count=3&website=default&prev_action=display_sub_list&session=40e57e082c5
8b559
ned
posted on 2/7/04 at 03:53 PM |
Thanks Ben! Email sent
Ned.
Alistair
posted on 4/7/04 at 01:40 PM |
Ned, I used the SPA speedo in my locost and the combined tacho/speedo in my indy. Both past at SVA and are very accurate. Best way to calibrate them
is by entering the wheel circumference rather than using the auto calibration.
DavidC
posted on 19/4/07 at 03:44 PM |
How have people mounted the sender for the SPA speedo? Do you use the front wheels/hubs, propshaft or driveshaft for mounting the magnets?
