Author: Subject: Duratec Crank Sensor Tool
big-vee-twin
posted on 4/1/12 at 06:28 PM Reply With Quote
Does anyone have a Duratec crank sensor alignment tool that I could borrow and send back, and a little guidance how to use?
Many Thanks
http://www.triangleltd.com
Doofus
posted on 4/1/12 at 07:39 PM Reply With Quote
Just start it up, put a timing light on and move it by hand to get the timing spot on.
pjay
posted on 4/1/12 at 08:03 PM Reply With Quote
You could also get it about right by eye and then adjust using MegaTune's 'Trigger Wizard'.
If you do manage to get the jig the following shows how to use it:
dave r
posted on 4/1/12 at 09:14 PM Reply With Quote
unless you are going to remove and replace it at a later date, it dont really matter.....
not as though you are trying to run it on the standard map
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
posted on 4/1/12 at 09:25 PM Reply With Quote
Old trick is before removing the old one use a quick spray with aerosol paint to create an outline witness mark on the block, then fit the new one so it stays within the marks outline.
