Author: Subject: Ford 7" Diff
Boltsy
posted on 8/11/13 at 07:46 PM Reply With Quote
Ford 7" Diff
Cash waiting for a 7" 3.38 ratio ford differential unit..
Must be lobro (bolt on drive shafts) not push in.
Limitation starts where the visions end - Jimmy Johnson
daniel mason
posted on 8/11/13 at 07:53 PM Reply With Quote
hi mate, you tried blatchat? the caterham lads run 7"ford sierra lsd, but usually push in type! a lot say you cant get 7" push in lsd but you defo can.ive had 2!
Kev99
posted on 8/11/13 at 07:57 PM Reply With Quote
What the going price for a 3.38 open diff fitted with the shafts for bolt on lobro ?
Boltsy
posted on 8/11/13 at 08:13 PM Reply With Quote
£350?
Boltsy
posted on 8/11/13 at 08:17 PM Reply With Quote
RGB cars have problems with push in shaft type. Not bothered about LSD either as it's the ratio of CW & P is the important bit. We add a Quaif ATB!
Kev99
u2u sent
daniel mason
posted on 8/11/13 at 08:20 PM Reply With Quote
road track race will probably do them for around £300
amalyos
posted on 8/11/13 at 09:44 PM Reply With Quote
Kevin,
What problems? Dave and I have been running them for 3 seasons with no problems, why carry the extra weight.
http://stevembuild.blogspot.com
daniel mason
posted on 8/11/13 at 11:25 PM Reply With Quote
^^^ thats what i thought.
why not use the tried and trusted caterham setup? should be bullet proof. i know many running big power through these!
Boltsy
posted on 9/11/13 at 10:10 PM Reply With Quote
Kevin,
I think it something along the lines of the shaft length interfears with the ATB LSD unit quaif do. Are you two running them too?
CNHSS1
posted on 9/11/13 at 10:56 PM Reply With Quote
The quaife ATB 7" i had couldnt run with LSD bolt in input shafts, could only be used with open diff input flanges or push in drivehshafts (ran it for 7 seasons with push in shafts)
amalyos
posted on 9/11/13 at 11:50 PM Reply With Quote
Kevin,
I run a Tranx and Dave has an ATB, so all bases covered.
gaz_gaz
posted on 10/11/13 at 07:51 PM Reply With Quote
I have a brand new 3.38 Crownwheel and pinion if your interested.
[Edited on 10/11/13 by gaz_gaz]
Boltsy
posted on 11/11/13 at 06:34 PM Reply With Quote
How much do you want for them?
