Author: Subject: Using rose joints on the end of the steering rack?
Northy
posted on 28/10/14 at 11:08 AM Reply With Quote
Does anyone know how this has been achieved?
Isn't the hole in a Cortina upright tapered?
I'm keen on working out how to do this so I can fit some wider wishbones easier, and play about with adjusting the bump steer
Thanks,
G
Graham
rodgling
posted on 28/10/14 at 11:40 AM Reply With Quote
I assume by using this kind of thing:
http://cbradleymotorsport.co.uk/suspension-steering/steering/steering/track-rod-end-rose-joint-adaptor-kit.html
Doctor Derek Doctors
posted on 28/10/14 at 12:32 PM Reply With Quote
What uprights do you have? I'm currently in the process of making up a kit to convert the Rally Design uprights to use rod ends on the steering rack to sell.
I was also thinking less than 1/2 the price of the CBradley kit as well!
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Northy
posted on 28/10/14 at 12:36 PM Reply With Quote
I have proper 'ord fashioned Cortina uprights
What is different on the Rally Design uprights?
G
[Edited on 28/10/14 by Northy]
Graham
posted on 28/10/14 at 01:06 PM Reply With Quote
The Rally Design Uprights have a straight hole in the steering arm and then have a stainless steel insert with an internal taper to fit the smaller RS2000 track rod.
I make all the parts individually so if you like I could design and make you up a set to fit a standard Cortina upright.
www.t89.co.uk
callan@t89.co.uk
posted on 28/10/14 at 04:51 PM Reply With Quote
Int bump steer all to do with the inner joint position on the rack gear? Not sure what using a different joint at the steering arm will help?
43655
posted on 28/10/14 at 05:55 PM Reply With Quote
If the rack can't be moved then moving the outer pivots to the correct position can help minimise bumpsteer
In the ideal design the ball-joint end of the steering rack is in line with the upper and lower wishbone pivots on the chassis
The tie rod should be at an angle whereby the UCA, LCA and it all intersect at the same point, as shown here
This will give no bumpsteer in a straight line
taken from
http://www.pro-touring.com/threads/90321-Wilwood-ProSpindle-and-bump-steer
Anyway in't the escort M14x2mm pitch? You could just use a female rose joint instead of the ball joint, no?
Also, what's wrong with standard ball joints? bit heavier but bound to last longer
posted on 28/10/14 at 06:26 PM Reply With Quote
Thats it, nice picture.
Northy
I thought that the steering arm should be parallel with the bottom wishbone to give zero bump steer.
The top wishbone affects camber change?
So therefore moving the outer joint up or down could help bumpsteer?
G
Graham
posted on 28/10/14 at 08:06 PM Reply With Quote
See how it lines up with the axle centre line? The steering arm is already designed with that in mind so making sure the rack is at the correct height would be thee first step.
43655
posted on 28/10/14 at 09:01 PM Reply With Quote
G
Nope, becuase for example if you have the rack in line with the upper wishbone, the angle of the tie rod would be parallel to the UCA instead.
But yes, I'd guess that has the most effect on bumpsteer
posted on 28/10/14 at 09:29 PM Reply With Quote
Both rack height and outer ball joint position effect bumpsteer. And both can be corrected.
www.t89.co.uk
callan@t89.co.uk
