Author: Subject: IVA Compliant alternatives for bonnet catches
PaulM
posted on 20/10/15 at 08:55 PM Reply With Quote
Other than those big chunky rubbery IVA compliant catches like this one.... here What other options work well and would be compliant? Has anyone tried aerocatches?
MsD
posted on 20/10/15 at 09:04 PM Reply With Quote
I have an aerocatch on mine as many others do, it passed iva last year and its lockable! Win win.
Mark.
PaulM
posted on 20/10/15 at 09:19 PM Reply With Quote
Mark.
Cool... any pictures? I guess I'd need four with two down each side?
Bluemoon
posted on 20/10/15 at 09:29 PM Reply With Quote
Duz, 1/4 turn, pain to fit but I like them
Linky: Duz fitting
Dan
[Edited on 20/10/15 by Bluemoon]
z2000
posted on 21/10/15 at 06:46 AM Reply With Quote
Yep same for me as MsD, four AeroCatches in the four corners of the bonnet. Passed IVA in September.
If you look at my photo below, you can make them out...if you want better photos let me know.
Henry
Multi-View
Multi-View
If it isn't broken; take it apart and fix it! Build PhotoBlog:
http://z2000.co.uk
jps
posted on 21/10/15 at 07:53 AM Reply With Quote
That bodywork looks NICE! Hope I get panel gaps as good as that!
z2000
posted on 21/10/15 at 10:59 AM Reply With Quote
http://z2000.co.uk
Daddylonglegs
posted on 21/10/15 at 11:45 AM Reply With Quote
Like Bluemoon, I used Dzus on my old Locost, fiddly to fit but nice and neat, and secure!
Smoking Frog
posted on 21/10/15 at 12:11 PM Reply With Quote
Dzus catch pic.
Bonnet vent
Bonnet vent
PaulM
posted on 21/10/15 at 05:43 PM Reply With Quote
Thanks for the replies..... Z2000, could you share some pics of how you've mounted the pin behind the catch?
I think the aerocatches are going to be the best option although I prefer the flush version as I could probably paint them body colour. Dzus are neat but would be a pain if I needed to get the bonnet off in a hurry I think.
z2000
posted on 21/10/15 at 09:44 PM Reply With Quote
I hope this helps....
If you want more photos I can take some next week when back at the car.
Basically I just marked the centre of the box section of the chassis and drilled straight through, then there is a nut and washer above and below the chassis which secure and set the height of the pins.
The holes were cut in the bonnet for the catches themselves by using masking tape and marking a centre line. Then using the supplied cardboard template it was easy to cut the main hole.
Once that hole is cut the catches sit inside and you can mark and drill the securing bolt holes and attach it.
Cheers.
Henry
http://z2000.co.uk
PaulM
posted on 23/10/15 at 10:48 AM Reply With Quote
Great, thanks.... I do like the aerocatches :-)
