locoboy
| posted on 8/11/16 at 01:39 PM |
earthing a metal table lamp
I'm part way through making a table lamp that is largely metal (aluminium)
I have a bulb holder that has the earthing tag on it but my problem is I don't have enough room to thread a 3 core (0.75 sq mm) all the way up
the inside of the lamp to the holder.
Is there any logical reason I can not earth it at the base of the lamp and then just run the 2 cores up to the holder?
Colin
Locoboy
r1_pete
| posted on 8/11/16 at 02:03 PM |
No as long as its a metal to metal joint at the bulb holder.
I'd heat shrink or something the live and neutral inside the tube to prevent chafing.
gremlin1234
| posted on 8/11/16 at 02:26 PM |
Colin
could you use 3 core 0.5 sq mm rated 3A, so ok for over 500W lighting.
approx 5.4mm diameter
http://uk.rs-online.com/web/p/mains-power-cable/7756066/
or nominal 5.5mm
https://www.tlc-direct.co.uk/Products/CA0dot5F3.html
v8kid
| posted on 9/11/16 at 05:37 AM |
You should earth at the lamp holder especially with aluminium. Reason is any conductive break will allow pArt of the lamp to become live. Aluminium is
highly reactive and a!I minimum oxide a great insulator so continuity of lamp over time will be poor
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
locoboy
| posted on 9/11/16 at 01:24 PM |
OK just checking, now if I use a plastic bulb holder the lamp body will still need an earth won't it because the lamp is metal?
Locoboy
r1_pete
| posted on 9/11/16 at 02:47 PM |
Correct, yes earth the metal bit.
locoboy
| posted on 11/11/16 at 10:39 AM |
Ok thanks for the tips.
Locoboy
