Author: Subject: Sierra upright weight
james h
posted on 17/11/16 at 07:37 PM Reply With Quote
For future reference, one Sierra upright with hub, no other fittings: 5.4kg
Sierra upright
Sierra upright
(Measured on two different scales and averaged)
I'd be interested to hear other uprights' weight.
James
limpetminer
posted on 18/11/16 at 09:44 AM Reply With Quote
Sierra Upright in alloy?
Does anyone make a lightweight version of the sierra upright?
adampage
posted on 18/11/16 at 11:07 AM Reply With Quote
Hi-Spec do, but not seen much info on it
Looks nice & shiny though......
adampage
posted on 18/11/16 at 11:09 AM Reply With Quote
Or actually, do they.....?
They used to, but their website now says they do Cortina uprights, but with Sierra Hubs, so a bit of a hybrid...
Sorry to confuse....
hughpinder
posted on 18/11/16 at 12:44 PM Reply With Quote
Exactly the same as a pair of mx5 ones then (5.4kg/pair)!
Mx5 standard front calipers 8.0 kg a pair inc bolts and the standard disks are 7kg/pair if anyone wanted to know (mk1 parts)
[Edited on 18/11/16 by hughpinder]
james h
posted on 18/11/16 at 02:19 PM Reply With Quote
From HiSpec themselves when I asked:
"The upright kit you are referring to uses a cortina upright for double wishbone geometry, but the hub is designed to use sierra fitment brakes.
the hub does not fit a sierra as we have updated the spec so that it runs double row bearings and a shorter stub axle to eliminate flex."
