Author: Subject: Manifold R1 carbs - throttle bodies?
Rena
posted on 24/4/17 at 08:57 AM Reply With Quote
I have a DanSt manifold with R1 carbs for my Zetec.
Thinking of going the throttle bodies route next winter. To keep the costs down it would be nice to use my existing manifold.
Any throttlebodies that will fit on my manifold?
SJ
posted on 24/4/17 at 02:21 PM Reply With Quote
The obvious answer is R1 throttle bodies.
Spacings should be the same so they should bolt straight up. As long as they have integral injectors you should be fine.
Stu
Rena
posted on 24/4/17 at 03:33 PM Reply With Quote
Stu
Are you sure?
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 24/4/17 at 05:00 PM Reply With Quote
Dan will make adapters to fit.....
Rena
posted on 24/4/17 at 05:08 PM Reply With Quote
Danst Engineering?
andygfc
posted on 24/4/17 at 06:19 PM Reply With Quote
I have some 2000 gsxr 750 throttle bodies
Bought to put on zetec, will need spacing, but is quite easy.
I've gone bike engine
£150 inc p
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 24/4/17 at 06:49 PM Reply With Quote
Danst Engineering?
Yes, thats his name, Dan Stanley.....
SJ
posted on 24/4/17 at 07:10 PM Reply With Quote
There are certainly R1 TBs that are spaced the same as R1 carbs. Not sure they are all the same though - later engines may be different.
Stu
Rena
posted on 25/4/17 at 04:12 AM Reply With Quote
Stu
I have found out R1 carbs are like 76-78-82,5 mm C/C.
The throttle bodies from a R1 after 2004 är paired, so it should be bodies before 2004.
[Edited on 25/4/17 by Rena]
Rena
posted on 25/4/17 at 06:30 AM Reply With Quote
£150 inc p
Pics?
Rena
posted on 25/4/17 at 06:31 AM Reply With Quote
Danst Engineering?
He can offer me a new kit and parts, but not any adapters that will make it fit.
lsdweb
posted on 25/4/17 at 07:12 AM Reply With Quote
I have a set of GSXR throttle bodies for sale - these are individual bodies so easily spaced. They are also single butterfly ones so no need to blank off second butterflies etc.
Link to for sale post
Wyn
