Author: Subject: Batteries
Myke 2463
posted on 6/8/17 at 05:40 PM Reply With Quote
Batteries
Any suggestions for an alternative to the pc680 odyssey battery
Be Lucky Mike.
russbost
posted on 6/8/17 at 06:03 PM Reply With Quote
Save around 4 - 5Kg for similar money & go to Li Ion
https://furoreproducts.co.uk/lithium-ion-batteries
craigdiver
posted on 6/8/17 at 09:14 PM Reply With Quote
A cheaper alternative to lithium is AGM
Leoch LPX600 Xtreme AGM Battery
High cranking amps, Can be deep cycled, Ideal racing battery
Equivalent to Odessey PC680.
Long storage life (1 year before needing a recharge)
Quick charging capabilities (4-6 hours to reach 100%)
3 YEAR GUARANTEE
Considerably lighter than lead acid
Ebay item 152632389652
£63
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
FuryRebuild
posted on 7/8/17 at 08:37 AM Reply With Quote
This is certainly how I'm going when I'm ready. They can also be packaged at weird angles if I remember correctly?
www.furyrebuild.co.uk
djtom
posted on 7/8/17 at 11:08 AM Reply With Quote
I've used a Yuasa 17Ah battery successfully for a few years - it's a golf cart battery I think. It turns a 2 litre zetec lump over quite happily and I've had no issues at all. It's small, light and cheap. I paid less than £30 about 3 years ago, looks like they've gone up by a tenner since then.
http://www.thebatteryshop.co.uk/np17-12i-yuasa-12v-17ah-lead-acid-battery-np17-12si-303-p.asp
russbost
posted on 7/8/17 at 01:17 PM Reply With Quote
Yes, can fit them any way you like, upside down if you wanted to! That Extreme AGM battery looks like a good buy if you're not bothered about the weight, fitting a Li Ion battery is about the most cost effective weight saver I know of!
FuryRebuild
posted on 7/8/17 at 01:25 PM Reply With Quote
I'm also interested in size - smaller volume sometimes means packaging can be better if it can be moved down and centerwards. One of the most awkward things I did on my fury last time was move the battery from up-high on the bulk-head shelf (good location for maintenance) down to the floor, in the engine bay, right next to the starter-motor. It was a lot of mass to move, and necessitated get a Varley red-top to do it. Worth it though.
