Author: Subject: Bike Carb Fuel Pump
myke pocock
posted on 11/1/19 at 08:27 PM Reply With Quote
Bike Carb Fuel Pump
I run Honda Fireblade carbs on my Skoda Estelle trials car and at present have a Facet cube pump feeding in to a Filter King filter/pressure regulator with a pressure gauge fitted. The Facet is quite old but I have just seen that they can be had to run at between 2 to 4psi which mine probably isnt At times I need to run at high revs on a competitive section for a short time. Would it be better to get one then run an in line filter before the pump and do away with the Filter King? Any ideas?
daviep
posted on 11/1/19 at 08:51 PM Reply With Quote
Get a bike pump, much more reliable.
A truly great library contains something in it to offend everyone.
posted on 11/1/19 at 09:08 PM Reply With Quote
Do you have a problem with insufficient fuel?
There are at least 3 versions of the facet pump and the fuel delivery is in the spec., I do t know what engine you have but I'd be surprised if the pump was inadequate. I have one for a 3.5 v8 in a land rover and it is able to cope with all loads.
It should be fitted with a metal filter which I have found can get blocked easily, all that needs doing is to remove it and tap on a block of wood to shake out the crud, or of course fit a new one but why spend the money unnecessarily. .
Visit China. Meet the child that made your trainers.
posted on 12/1/19 at 12:31 AM Reply With Quote
Like daviep says get the bike pump, they are interrupters and thats all you need along with a filter
SJ
posted on 12/1/19 at 08:21 AM Reply With Quote
+1 0n getting a bike carb pump. Cheap, reliable and designed for the job.
