Author: Subject: Fuel Pipe Size
the_big_1
posted on 23/7/19 at 06:44 AM Reply With Quote
Fuel Pipe Size
Hi Guys,
Would 8mm fuel pipe be OK to use on a 2.0L Zetec Silver top running the standard injection system?
Carl
40inches
posted on 23/7/19 at 07:41 AM Reply With Quote
I use 8mm on the Jag 3litre engine, not a problem
Myke 2463
posted on 23/7/19 at 07:54 AM Reply With Quote
8mm o/d copper on silvertop with Jenveys no probs. no drop in fuel pressure on RR at 7k.
Be Lucky Mike.
hughpinder
posted on 23/7/19 at 09:29 AM Reply With Quote
8mm OD should be fine - 8mm bore is good for up to 500 bhp.
http://www.motorsport-developments.co.uk/tech_articles/FAF286_tech.pdf
dellyend1
posted on 23/7/19 at 02:55 PM Reply With Quote
I've got 8mm on my silvertop and all is working as should be
Hope that helps
Jeremy
the_big_1
posted on 23/7/19 at 04:47 PM Reply With Quote
Thanks guys!
8mm it is then!!!!
the_big_1
posted on 18/8/19 at 05:11 PM Reply With Quote
Hi guys,
If you read the article below, they have pipe size as 8mm in side diameter. Most below talk about 8mm outside diameter?
For the 2.0l Zetec on standard injection, should it be 8mm outside or inside diameter?
Many thanks!
