ragindave
posted on 30/5/22 at 12:24 PM |
Type 9 gearbox leak
Type 9 gearbox leak I thought it was possibly the input shaft seal I removed the bell housing and found no gasket between the bell housing and gear
box the selector shaft protrudes from what I guess is an open hole so I guess the gasket is important and would stop the gear oil escaping into the
bell housing onto the clutch.
I have purchased a seal kit so I intend on doing them all any tips on fitting these and getting it oil tight would gasket sealant help what do you
recommend?
theconrodkid
posted on 30/5/22 at 01:06 PM |
sposed to be a gasket there, i would try to find one, failing that, gasket paper and make one
who cares who wins
pass the pork pies
mcerd1
posted on 30/5/22 at 01:19 PM |
like these ones:
https://www.burtonpower.com/bellhousing-gasket-type-e-9-gbrk704.html
https://www.burtonpower.com/bellhousing-gasket-type-e-9-cometic-gbrk704com.html
[Edited on 30/5/2022 by mcerd1]
melly-g
posted on 30/5/22 at 01:28 PM |
I cut my own from a fosters lager box!
