New Topic New Reply
Author: Subject: Clearance?
drmike54
posted on 1/11/05 at 01:32 PM Reply With Quote
Clearance?
How much space between the transmission and the vertical frame members? Is 1 inch OK?
Ignore the photo date, this is not a picture from the future. Rescued attachment chassis 10-23 small.JPG
Started Welding the chassis!!!!
posted on 1/11/05 at 01:42 PM Reply With Quote
If you mean fore-and-aft clearance (i.e. the back of the bellhousing) I have just 5mm clearance.
DJ
ned
posted on 1/11/05 at 02:05 PM Reply With Quote
yeah as david says, 1 inch is plenty, mine is down in mm's..
Ned.
beware, I've got yellow skin
Danozeman
posted on 1/11/05 at 02:27 PM Reply With Quote
Mine will be about 5 mm. 10 at the very most.
Dan
Friberg
posted on 1/11/05 at 02:36 PM Reply With Quote
I have around 20 mm to allow for some engine/gearbox movement... Some of you would be surprised to see how much an engine actually moves when accelerating hard.
>>drmike
Since you too are building with a turbo engine I would adivice you to have some extra clearance for when "Mr Tourqe" comes visiting
[Edited on 1/11/05 by Friberg]
An engine without turbo sucks!
stevebubs
posted on 1/11/05 at 03:05 PM Reply With Quote
Looking at your chassis, you don't have much pedal space as your gearbox seems to be right back in the tunnel. You may want to consider if you have enough room to operate the pedals..
If not then you may want to explore moving it forward or offsetting the engine / gearbox slightly to the passenger side.
[Edited on 1/11/05 by stevebubs]
New Topic New Reply
