<<  1    2  >>
Author: Subject: Sierra Lobro drive shaft bolt failure
Mix
posted on 2/1/06 at 11:29 PM Reply With Quote
I'm with Jono on the wirelocking issue.
Loss of torque can arise in a nuber of ways, bolt streaching, fretting of the joint, corrosion are three that spring to mind. It has always been my understanding that the function of locking wire was to retain the fastener in the event of a loss of torque and thus preventing 'catastrophic failure' which may occur if the fastener falls out completely, (or in the case of aircraft, if an unrestrained fastener interferes with a critical component)
Mick
RichieC
posted on 2/1/06 at 11:35 PM Reply With Quote
Yep, but when tension is applied in the direction of tightening, and of course done correctly, said wire will prevent the fastener from rotating in the other direction. It physically cannot rotate as it would be pulling the other bolt head tighter if it tried to.
Were not talking about locking the bolts to something else like a hole but to each other, thats the difference.
I was an aircraft technician in a previous incarnation and in the numerous examples Im thinking of, items were locked to prevent them loosening, not to prevent them falling out, if it had got to that stage, you were already in the catostrophic failure you talk about.
Rgds
Rich
RichieC
posted on 2/1/06 at 11:41 PM Reply With Quote
Hope my dodgy paint skills explain it better, Ive used an example of just 3 bolts but the same principle applies.
Fingers crossed I didnt anti lock them but its getting late
Each of the bolts are being pulled clockwise and cannot rotate anti clockwise (assuming conventional threads).
All of this asside, it shouldnt be required; it wasnt for Ford, but for piece of mind it would help. I dont see how you could go wrong with the right bolts, fitted with the right spready thingies (for belt and braces) torqued up correctly.
Rgds
Richie
[Edited on 2/1/06 by RichieC] Rescued attachment Locking Wire.JPG
Stu16v
posted on 3/1/06 at 12:58 AM Reply With Quote
Mick
Lockwiring *is* there to retain the fastener in the event of loss of torque. But if you remove the reason behind the 'loss of torque', you don't need lockwiring. Ford didn't need it, why should we? IMHO prepare the surfaces properly, tighten correctly, add loctite to the equation if required, and there won't be a problem...
NS Dev
posted on 3/1/06 at 09:06 AM Reply With Quote
Exactly!
smart51
posted on 3/1/06 at 10:45 AM Reply With Quote
When I reassembled the car yesterday I found that it is a bit more fail safe than I thought. The nose of the shaft sits in the cup of the stub axle and so won't fall out, even if the bolts all come out.
NS Dev
posted on 3/1/06 at 11:16 AM Reply With Quote
In a similar vein, on the grasser I don't run circlips on the shafts.
The shafts have slightly rounded noses (not std sierra shafts, custom made ones) and the splines are 4" long at each end.
The shafts are then free to slide through the CV's at each end which gives more available travel, and they cannot escape from the cv's at each end of the travel as they are retained by the cups.
RichieC
posted on 16/1/06 at 06:04 PM Reply With Quote
Just an update for anyone whos interested, the banana shaped lock plates are still available from Ford at about a quid a piece.
I cannot see how 12.9 grade bolts with these and a spot of loctite could come loose, "belts and braces".....and a piece of string maybe
Rgds
Rich
[Edited on 19/1/06 by RichieC]
RichieC
posted on 19/1/06 at 06:04 PM Reply With Quote
Locking Plate part number is F1018715
£0.95p each + VAT
Rgds
Richie
<<  1    2  >>
