posted on 3/8/06 at 09:13 PM |
whats the difference?
whats the difference between these two parts? I cant spot any except one is called open body, the other is closed body. Which means, whatever i get,
it will be wrong.... Plus, does anyone know where to get them cheaper?!
from here http://www.s3i.co.uk/forkstudOB.php
from here http://www.s3i.co.uk/forkstudCB.php
any ideas?
tks
posted on 3/8/06 at 09:15 PM |
mhhh
i only see difference in the top where the threadstarts..
the above one misses a part..
but don't know if thats the reason..
Tks
t.j.
posted on 3/8/06 at 09:17 PM |
The lower is smaller
I don't see any difference between to two
k33ts
posted on 3/8/06 at 09:30 PM |
dont know what size your after but you could make something up with these
http://www.rallydesign.co.uk/catalog/advanced_search_result.php?keywords=g1312&osCsid=c30b344061c6666a91846741a90dd590
tukcustoms.com
tks
posted on 3/8/06 at 09:46 PM |
whats it for??
you could easy weld some up with flat plate and threaded bar not??
just cut the pieces weld it, then drill it..
else just buy it!
Tks
Chippy
posted on 3/8/06 at 10:23 PM |
If memory serves, I think they are both closed body. Open body has a complete ring at the end, and no clevis pin. Maybe wrong, may be the other way
round, but you get the idea. atb Ray
posted on 3/8/06 at 10:28 PM |
Those forks are normaly part of a turnbuckle, and the "open" and "closed" body normaly refers to the threaded sleeve into
which they screw. An open body has a slot cut down the length of the sleeve so you can see how much thread is engaged.
I'm wondering if those forks are supplied with the "body" but just not shown?
NS Dev
posted on 4/8/06 at 11:53 AM |
Cheap source, Racers hardware (sure they have a web site cant find it tho) tel 01733211311
think they are a couple of quid, stock cars use em on the wishbones
posted on 4/8/06 at 06:18 PM |
Cheers for all the help guys (except tj, that was bloody useless mate )
I'll follow up nats link, see what i can find. They are for my new wishbones, and i need them to be 3/8 unf as ive already got the inserts made!
