Author: Subject: Alternator Wires - Where to ?
richyo
posted on 15/8/06 at 12:42 PM Reply With Quote
As the heading says. I'm using a x-flow with standard alternator. Where can I put the red wires to ? Do they have to go directly to the battery positivice or can I take them there via the starter or via the solenoid ?
It an inertia starter so solenoid is remote.
TIA
Richyo
RazMan
posted on 15/8/06 at 05:06 PM Reply With Quote
Depends on the make of your alternator but the main charging wire can go to the battery via the starter solenoid. You will probably have two more connections, IG & L which go to a switched live and your panel lamp.
[Edited on 15-8-06 by RazMan]
Raz
k33ts
posted on 15/8/06 at 08:02 PM Reply With Quote
main charge wire needs togo to battery
tukcustoms.com
MikeR
posted on 15/8/06 at 08:11 PM Reply With Quote
according to the premier wiring loom, it can go via the starter solonoid feed (ie not the bit that only goes live when the starter is turning but the other bit to the solonoid)
k33ts
posted on 15/8/06 at 08:14 PM Reply With Quote
in other words straight to the battery to save on confusion
tukcustoms.com
MikeR
posted on 15/8/06 at 08:21 PM Reply With Quote
yeah ok - fair point, but i was trying to say, it doesn't have to be one physical wire, it could join another large wire going to the battery.
richyo
posted on 16/8/06 at 06:56 AM Reply With Quote
Thanks all
I'll just take straight to battery.
