Author: Subject: Throttle Pedal Stop
The Doc
posted on 15/6/07 at 12:32 PM Reply With Quote
Throttle Pedal Stop
Do we need one?
If so - behind the peal on the bulkhead?
What did you do?
TA
The Doc
posted on 15/6/07 at 12:33 PM Reply With Quote
That's pedal not peal!
Bluemoon
posted on 15/6/07 at 12:35 PM Reply With Quote
Yes you need one to stop you snaping the cable etc.. Nut welded on bulkhead behind the pedal and a long bolt and lock nut works well..
Dan
[Edited on 15/6/07 by Bluemoon]
smart51
posted on 15/6/07 at 05:02 PM Reply With Quote
I used a long coach bolt with a nut either side of the bulk head. Coach bolts have a nice big domed face instead of a smaller hex head.
millenniumtree
posted on 15/6/07 at 05:15 PM Reply With Quote
Isn't that what the floor is for?
My old Camry's clutch pedal went all the way to the floor - which meant if the floor mat slid up underneath the pedal, you couldn't start the car!! Thinking back on it now, it probably had an adjuster.
The Doc
posted on 23/6/07 at 05:00 PM Reply With Quote
Being a bit of a short-arse and also having a simple 'bench' seat I think my pedals are a little too far away from the bulkhead for the 'bolt adjuster option'.
Any alternative suggestions?
Mike
Simon
posted on 24/6/07 at 11:44 AM Reply With Quote
Looks a bit untidy, and was how I did mine - piece of steel wire bolted to top of pedal and to throttle pedal bracket. Nice and cheap, adjustable, just didn't look much.
Simon
