Author: Subject: nitromors on aluminium ?
dave r
posted on 23/7/07 at 04:09 PM Reply With Quote
does it work or does it damage the alloy ???
matt_gsxr
posted on 23/7/07 at 04:12 PM Reply With Quote
I tried it on some revolution alloys, and it is absolutely fine.
I guess this means it isn't acid or alkali, as my o-level chemistry would suggest that either of these would disolve ali.
As they always say "Try it on a corner that you don't notice first!"
Matt
donut
posted on 23/7/07 at 04:17 PM Reply With Quote
As long as you wash it off after it has done it's job then i guess it would be fine.
caber
posted on 23/7/07 at 04:44 PM Reply With Quote
Nitromors is solvent based so has historical application for removing 12 coats of squaddie brush applied cammo paint from ex military landrover panels without leaving you with a lace effect!
However you do get lace if it was only the paint holding the corroded ally together!
Caber
oadamo
posted on 23/7/07 at 06:22 PM Reply With Quote
ive tryed this on alloy wheels before and it didnt work very well.
adam
Jimbob
posted on 23/7/07 at 06:47 PM Reply With Quote
Yup works fine just make sure you clean it off properly after
James
greggors84
posted on 23/7/07 at 07:06 PM Reply With Quote
We use NitroMors on our ali tub side panels and works a treat.
Chris
The Magnificent 7!
dave r
posted on 23/7/07 at 08:19 PM Reply With Quote
adam
it is alloy wheels i want to try it on
they will be a bit of a sod to bead blast cos of all the corners on them ;/
ed_crouch
Its function is to permeate through the paint by solvent action, and then it off-gasses something fairly benign (nitrogen IIRC). The gas production physically lifts the softened paint/lacquer off the substrate.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
DarrenW
posted on 23/7/07 at 09:46 PM Reply With Quote
Some wheels have a polyester / plastic coating. Bit like lacquer but a lot thicker. Nitromorse can have a bit of bother getting thro this.
ice refurbed wheels myself and also had some pro-done. Not worth the diy hassle IMHO. Probs bettr to just buy some good ones. Refurb can be false economy on budget end wheels. OK for rare or expensive alloys.
