Author: Subject: Handbrake Lever
Cubby
posted on 8/3/08 at 10:12 PM Reply With Quote
Handbrake Lever
My standard sierra hanbrake looks like its going to impinge on the gear lever. Has anyone tried moding the handbrake to reduce it length ? Don't want to move it backwards as its not going to be easy to resite the mounting brakets.
eznfrank
posted on 8/3/08 at 10:13 PM Reply With Quote
Could you offset it to one side instead?? Don't believe it needs to be central for SVA or any other reason?
blakep82
posted on 8/3/08 at 10:22 PM Reply With Quote
hmm, interesting question. I'm not sure if handbrake levers are allowed to be cut and rewelded. i guess they're not as critical as a brake pedal though
________________________
posted on 8/3/08 at 10:32 PM Reply With Quote
Check my blog, I've used a Rover 200 lever thats much better than the Ford one.......
posted on 8/3/08 at 10:33 PM Reply With Quote
They can be cut down. I'm sure someone on here has done a few and written a detailed guide, with photographs on how to alter it. Just can't remember who it was.........
Phil
ayoungman
posted on 8/3/08 at 10:38 PM Reply With Quote
I cut mine and re welded the bracket in order to lower mine. The handle is now almost flush with the tunnel top. Would this help it miss the gear lever?clicky
[Edited on 8/3/08 by ayoungman]
"just like that !"
Cubby
posted on 8/3/08 at 10:48 PM Reply With Quote
Thanks guys food for thought.
I thought I'd seen someone who had done it but numerous searches have proved fruitless.
Hammerhead
posted on 8/3/08 at 10:50 PM Reply With Quote
Phil
I've done it:
see blog below
[Edited on 8/3/08 by Hammerhead]
NeilP
posted on 8/3/08 at 11:11 PM Reply With Quote
The old Luego boys, Matt and Grant used to do it - Both on here, Matt is Carsarva and Grant is Optimum Balance Products.
Before we get the floodgates open please note this is just a fact and information not a recommendation...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
andrew.carwithen
posted on 9/3/08 at 12:04 AM Reply With Quote
I've shortened mine using 'Hammerhead's' method.
(There's a pic in my archive under 'shortened handbrake' which shows both a standard and shortened handbrake for comparison.)
Paul (Notts)
posted on 9/3/08 at 07:42 AM Reply With Quote
Old Luego cut mine down - charged me £15 for the end product.
posted on 9/3/08 at 09:29 AM Reply With Quote
Cut and shut mine , easy to do if you go about it logically
Cubby
posted on 9/3/08 at 09:42 AM Reply With Quote
Once again you've come up trumps !
Thanks guys !
Cub
Hammerhead
posted on 9/3/08 at 04:52 PM Reply With Quote
if I was to do it again I reckon i'd cut the round handle part of the shaft, like luego, and shorten it there rather than way back near the mech, if that makes sense?
[Edited on 9/3/08 by Hammerhead]
