<<  1    2  >>
Author: Subject: Moving along nicely...front brakes
Doug68
posted on 19/6/08 at 04:59 AM Reply With Quote
That's good then, so even if the hubs turn out not to be appropriate it won't waste the work you've done to date with the uprights.
Doug. 1TG
Sports Car Builders WA
Alan B
posted on 19/6/08 at 10:53 AM Reply With Quote
Pretty sure I'll make these work even if it turns out that I have to use modified CV ends....I can find used ones quite easily after a bit of research last night. I really want to keep using what I have because of their wide availibility over here, but obviously a sound and safe solution is the main priority.
<<  1    2  >>
