New Topic New Reply
Author: Subject: Chassis pics up to date.
iwbunting
posted on 3/1/05 at 05:29 PM Reply With Quote
phelpsa
posted on 3/1/05 at 06:00 PM Reply With Quote
Where?
EDIT: Found them, in the archive. Looking good.
Adam
[Edited on 3-1-05 by phelpsa]
phelpsa
posted on 3/1/05 at 06:01 PM Reply With Quote
P.S. Did you get the IRS done?
Did you use my dimensions?
posted on 3/1/05 at 06:57 PM Reply With Quote
Looks like a very strong design. Are the rear uprights alloy?
phelpsa
posted on 3/1/05 at 07:06 PM Reply With Quote
Steel I would say.
Adam
phelpsa
posted on 3/1/05 at 07:29 PM Reply With Quote
Heres my IRS so far:
Top
Bottom
Ready for welding in and brackets.
Adam
iwbunting
posted on 3/1/05 at 08:56 PM Reply With Quote
Phelspa
Hi to all.
No didnt use anyones dimensions in the end.Read all the books and came up with my own,although length of bottom wishbone within a few mill of Johnn's.
Irs has 2 degrees inclusive toe-in inbuilt.Top wishbone uses a transit track rod end as per front for camber adjust,also built in some height adjustment on inner wishbone mountings to allow for road/track adjustment.I will post clearer full assembly pics as i take them.
Happy new year to all.
iwbunting
posted on 3/1/05 at 09:01 PM Reply With Quote
Phelspa
Ps.
Uprights are cnc machined in steel and as seen in the pics,they sit together like a jigsaw prior to fillet welding on outer face.
Will hopefully have them finished and dry assembled with wishbones before weekend so will post more pics then.
If anyone wants cad drawings for the work so far U2U me.I can send in DXF or DWG.
Front end will have inboard shocks and a heavily re-worked chassis.
phelpsa
posted on 3/1/05 at 10:19 PM Reply With Quote
Great, you've insprired me to go and weld it all up and fit the brackets.
Adam
Sven
posted on 4/1/05 at 07:02 PM Reply With Quote
Which hubs are you using?
-Sven
iwbunting
posted on 4/1/05 at 08:44 PM Reply With Quote
Hubs
Sven.
I am using ford sierra hubs,shafts diff and dsics etc.
Sven
posted on 5/1/05 at 01:51 AM Reply With Quote
Sven.
Thanks mate. What's the impetus, aside from it being fun/cool, to design and build your own uprights? Weight, geometry?
-Steve
New Topic New Reply
