John P
posted on 23/12/09 at 01:00 PM |
Has anyone actually got a car with motorcycle coilovers on the road?
I know that a few years ago there was a lot of talk about using bike coilovers as a locost source of suspension units.
From what I can find most of the discussion revolved around Yamaha R1 or R6 coilovers used with pushrod suspension.
I'm just planning for later but wondered if anyone had actually got a car on the road since most of the info I've found was from those
still building.
I know shocks are very important to handling and that buying GAZ or similar would be ideal but I don't have the funds for that solution (and the
way things are going on the job front probably won't) whereas I do have plenty of time.
John.
liam.mccaffrey
posted on 23/12/09 at 01:32 PM |
Yeah chrisf on here built, raced, drove and sold a fireblade 7 with bike coilies on the back.
Iirc Bob C and he did a lot of solidworks modelling to get the rocker ratio right.
Build Blog
Build Photo Album
steve m
posted on 23/12/09 at 01:38 PM |
I had brand new honda goldwing coil overs at the back on my locost,
they lasted about 100 miles !!
one had no oil and the other broke the mounting lug off
posted on 23/12/09 at 06:04 PM |
Bike shocks are not cheap either!
It's Evolution Baby!
Doug68
posted on 24/12/09 at 01:05 AM |
Typical sports motorcycles these days have roughly 4.5" to 6" of rear wheel travel.
Therefore the motion ratio used on a Locost will not be that different to how the thing was designed to be used on the bike. If anything it will be
higher given the normal 4" movement aim at for Locosts.
Suspension on motorcycles is typically far more sophisticated than on a production car, big efforts are made to reduce "stiction". For
example it’s not unusual for all the bearing in the rear suspension linkages and pivots to be needle roller bearings.
On the other side of things the spring rates and damping may not be where you want it, the unsprung mass on a bike will be a lot less than on car for
sure.
Steve Grabber with his La Bala uses bike shock as part of the design:
http://www.grabercars.com/
[Edited on 24/12/09 by Doug68]
Doug. 1TG
Sports Car Builders WA
