airframefixer
posted on 18/9/06 at 01:30 AM |
miata upright upper ball joint taper
hey guys, im building a locost using miata front and rear uprights. the stock miata uses a ball joint pressed into the upper-a arm. i would like to
use the configuration as descibed in "the book" by using a tie rod end with a male thread that can used to make camber adjustments.
does anyone know the upper ball joint taper used in the front of a miata
or know of an existing tie rod end that will fit.
btw DOT has banned the use of spherical bearings/rod ends in suspension components were i live, so ive heard.
robertwa
posted on 18/9/06 at 03:44 AM |
I hear that the Moog E323S tie rod end has the same taper. It is a bit short though, so may be difficult to engage enough threads for comfort when
tightening it up on the upright.
Best thing to do is to find out what Westfield are using on their new Miata based car....
Bob C
posted on 20/9/06 at 11:18 AM |
MK engineering were kind enough to let me whack their taper reamer through my mx5 upper fronts - so I used the transit drag link c.f. book
Bob C
airframefixer
posted on 20/9/06 at 08:32 PM |
right on, ill have alook at th moog model. ill see if i can use a shear castleated nut to get the cotter pin holes lined up
