Author: Subject: Mirrors and full cage
Avoneer
posted on 11/7/07 at 09:03 PM Reply With Quote
Anyone got a good solution for fitting mirrors to a full cage that would meet SVA?
I was thinking simple round scooter mirrors with an 8mm thread and a ring of ali round the cage leg and the ends bend out at 90 degrees and the 8mm thread of the mirror clamping it tight.
Pat...
Avoneer
posted on 11/7/07 at 09:06 PM Reply With Quote
Or shall I just fit some tidy mirrors to the scuttle?
Thanks,
Pat...
blakep82
posted on 11/7/07 at 09:07 PM Reply With Quote
my pickup chassis has rivnuts (i think they're called) drilled and pressed into a non structural tube
________________________
Fozzie
posted on 11/7/07 at 09:12 PM Reply With Quote
Thanks,
Pat...
IMHO... nice tidy mirrors on the scuttle!
No problems at all with SVA....
Fozzie
shortie
posted on 11/7/07 at 09:31 PM Reply With Quote
Yep, nice mirrors on scuttle
marc n
posted on 11/7/07 at 09:39 PM Reply With Quote
could use rubber lined metal p clips
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
Avoneer
posted on 11/7/07 at 10:00 PM Reply With Quote
Cheers Marc - simple!
I have a pair of racetech's that I was going to use after SVA and rivet the neat bracket to my cage, but now I don't know whether to use some motorbike ones on the scuttle.
Hmmmm,
Pat...
Avoneer
posted on 11/7/07 at 10:04 PM Reply With Quote
What's the normal bike ones that everyones using?
May buy some and see what looks best when the time comes.
Pat...
Fozzie
posted on 11/7/07 at 10:07 PM Reply With Quote
I used Fireblade mirrors Pat.
Fozzie
Avoneer
posted on 11/7/07 at 10:10 PM Reply With Quote
Are they the norm that eveyone seems to be using Auntie Fozzie?
Ta,
Pat...
ReMan
posted on 11/7/07 at 10:21 PM Reply With Quote
mainly, also R1 mirrors popular too.
I found they sat at a better amgel and the "boot " still worked properly with little modification.
TimC
posted on 11/7/07 at 10:23 PM Reply With Quote
Doesn't help you on side mirrors but have you seen the large roll-bar mounted mirrors that some of the RGB boys use? I think they're from Longacre and look perfect.
Fozzie
posted on 11/7/07 at 10:30 PM Reply With Quote
Ta,
Pat...
Oi! ya cheeky whipper-snapper !!!...
I got mine about 4 years ago now, they do sit nicely, and can be adjusted like normal mirrors!....
I don't know what others with cages fitted for SVA have used, I expect since I got mine (which are 'E' marked btw), there are more choices.....
As far as I know, I was the first to SVA with full cage in situ... (well down south anyway...according to Mitcham VOSA).
Fozzie
worX
posted on 12/7/07 at 05:44 AM Reply With Quote
they aren't that easy to see, but there is a pair of mirrors mounted directly onto this cage from MAC1
Danozeman
posted on 12/7/07 at 05:47 AM Reply With Quote
Ive got these hayabusa ones to go on my scuttle. Theyr cbr ones i have on there are the minute and i can see bugger all as theyr small. I havent sva'd yet though.
Dan
