<<  18    19    20    21    22    23    24  >>
Author: Subject: Warner R4 Build Diary
pocket rocket
posted on 30/1/09 at 02:27 PM Reply With Quote
best of luck mate
wish mine would be ready before dam iva price!
Valtra
posted on 30/1/09 at 06:27 PM Reply With Quote
Do you need to check emissions?
My tester also told me that because my boot had no cover , technicly it is also tested for sharp edges (there were none) as yours is an open design do you need to install a temporary engine cover for example?
[Edited on 30/1/09 by Valtra]
"If it looks like it works and it feels like it works, then it works"
nitram38
posted on 30/1/09 at 06:50 PM Reply With Quote
I am going to put a 1" X 1" mesh over my engine.
I had to do it on the F1-2 as the tester said my engine had too many projections.
The atom has to do the same to pass and these bits disappear after the test!
cloudy
posted on 30/1/09 at 07:10 PM Reply With Quote
Pre 95 engine, so no emissions - but I suspect I will need to cover the engine...
How "permanent" does this have to appear? I don't want to drill loads of mounting holes...
James
www.warnercars.com
nitram38
posted on 30/1/09 at 07:14 PM Reply With Quote
If you form a piece of steel band that wraps around your rails and clamps like on a bike exhaust box, then you will not have to drill your chassis.
That is what I am planning to do
cloudy
posted on 30/1/09 at 07:16 PM Reply With Quote
Are tie wraps going to be obviously temporary?
James
www.warnercars.com
nitram38
posted on 30/1/09 at 07:19 PM Reply With Quote
James
That depends on your tester, but I would say not permenant, although you could argue as most cables are held permenantly, they might say that if you cut them for access, that they might not be able to be replaced if you are not carrying any.
cloudy
posted on 30/1/09 at 07:31 PM Reply With Quote
Yes good point, perhaps if I cable tie some mounts to the chassis then screw the cover on - allthough that might look equally as "disposable", I'll just have to see what I can do...
Actually I think I can get away with 4 mounts, so maybe just rivet in some ally corner pieces, that way I just have to fill in 4 or 8 4mm holes...
James
James
[Edited on 30/1/09 by cloudy]
www.warnercars.com
Valtra
posted on 30/1/09 at 07:39 PM Reply With Quote
James
James
jubilee clips or stainless cable ties (screwfix) maybe ?
nitram38
posted on 30/1/09 at 07:47 PM Reply With Quote
James, take a look at a bike exhaust box clamp. It is a complete circle with two folded tags that a bolt can go through.
Make some to wrap around your rails and the bolt/tags will go through your mesh. No holes in your chassis required.
jabbahutt
posted on 4/2/09 at 07:55 AM Reply With Quote
Any more progress? I'm keen to see the latest photos to see how she's coming along.
Nigel
cloudy
posted on 4/2/09 at 08:07 AM Reply With Quote
It's all little details at the moment, hoping to get some major components like the tank in this weekend...
James
www.warnercars.com
cloudy
posted on 9/2/09 at 11:12 AM Reply With Quote
Some rather large (rear ) discs arrived today
cloudy
posted on 9/2/09 at 08:59 PM Reply With Quote
Springs fitted, and correct size brake discs fitted at the rear...
A few blatant brake porn pics:
www.warnercars.com
Gakes
posted on 9/2/09 at 09:35 PM Reply With Quote
Looking so hot!!!!
jabbahutt
posted on 10/2/09 at 10:59 AM Reply With Quote
That's indeed looking awesome. Can't wait to see an up to date whole car photo.
Hurry up and finish so we can see some photos to drool over.
pocket rocket
posted on 10/2/09 at 04:24 PM Reply With Quote
dude thats hot
wilwoods on the rear aswell... should stop well lol.
did the make the rear uprights yourself?
cloudy
posted on 10/2/09 at 05:57 PM Reply With Quote
rear uprights are from MNR, but ive lightened and modified to take rear cycle wings...
James
www.warnercars.com
neilj37
posted on 11/2/09 at 10:42 AM Reply With Quote
OMG just soiled myself
cloudy
posted on 11/2/09 at 07:08 PM Reply With Quote
Custom tanks arrived and test fitted!
Made by Paul Talbot (U2U for contact details) recommended by russbost - £200
Internal anti surge pot too about 4.5 UK Gallons total....
www.warnercars.com
cloudy
posted on 12/2/09 at 07:57 PM Reply With Quote
Tanks are all plumbed in, so a chance to clear out the cobwebs!
Video
[Edited on 12/2/09 by cloudy]
www.warnercars.com
posted on 12/2/09 at 08:37 PM Reply With Quote
Sounds great.
Phil
Meeerrrk
posted on 12/2/09 at 09:28 PM Reply With Quote
sweeeet!!!
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
Hammerhead
posted on 13/2/09 at 02:10 PM Reply With Quote
mental!
pocket rocket
posted on 16/2/09 at 12:00 AM Reply With Quote
dam thats the best thing iv seen all week
good work dude, can't wait to see it at some shows!
Dam...iv consused my ability with my intentions!
