<<  1    2  >>
Author: Subject: swap form pinto to duratec start
goaty
posted on 27/12/09 at 10:59 AM Reply With Quote
its looking great. i do like the take off plate, came out really well
Micael
posted on 28/12/09 at 08:24 AM Reply With Quote
Nice build
How does the combustion chamber looks like? I had the same butterfly problem and the head had severe markings.
[Edited on 28/12/09 by Micael]
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
Stuart_B
posted on 28/12/09 at 10:27 AM Reply With Quote
hi, the head was not to bad, a couple of little dinks, which will not make to much differance, it was just the piston which was badly damaged, a thin scartch down the bore which came out with a light hone.
and the vaules where untouched, so i did not need to replace them.
so not to bad, but it was a shock as i did not know about the promblem.
but now it has new piston's and rods now.
i think my piston was a bit worse than yours: piston
piston
so what are you going to do with yours, as you have 2?
cheers
stuart
cheers
Micael
posted on 28/12/09 at 11:04 AM Reply With Quote
My combustion chamber looked almost the same as the piston. So don't know if it cam be repaired.
I have two engines. One with bearing failures(1 and 2 cyl) and one engine with a piston/butterfly failure.
The plan is to use the block and head from the engine with bearing failures. With the crank and 3 pistons/conrods from the "bytterfly engine" and one piston/conrod from the "bearing" engine.
All with new bearings, rings and ARP-bolts @ the big end.
My plan is to use Gixxer TB with MS, as i did on my Zetec. However i have started to look into using an Eaton M-62 instead.
Micael Moose Åman
Stuart_B
posted on 28/12/09 at 11:35 AM Reply With Quote
wow that is a clean engine, how did you do that?
as well will be using new rings or not?
with the megasquirt have you found a base map yet?
cheers
stuart
Micael
posted on 28/12/09 at 01:13 PM Reply With Quote
It's amazing what some paint can do
To get an engine start with MS is not that hard. There are a lot of guides out there to get it run.
With an wideband O2 sensor and MegaLogViewer VE analyzer it is pretty easy to get a good map. However a couple of hours on a rolling road is a good investmet as well.
Do you plan to use MS?
Micael Moose Åman
Stuart_B
posted on 28/12/09 at 01:23 PM Reply With Quote
nice, yes i plan to use MS, i have it sitting in front of me now.
i am also got to buy the wideband sensor still.
stuart
Micael
posted on 28/12/09 at 07:23 PM Reply With Quote
I have used Innovate LC-1 wideband sensor. But i think the "JAW" will work aswell.
Micael Moose Åman
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 27/1/10 at 08:21 PM Reply With Quote
are there any more updates to this??
flak monkey
posted on 27/1/10 at 08:49 PM Reply With Quote
Stuart had to abandon it as he couldnt get insurance to cover him on a 2 litre
Sera
http://www.motosera.com
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 27/1/10 at 09:02 PM Reply With Quote
thats a big shame as this was a good looking thread. Out of interest what age is he? We are thinking of a duratec engine swap and my son will be 23/24 when it is finished
flak monkey
posted on 27/1/10 at 09:05 PM Reply With Quote
18 IIRC
I got insurance on the 2 litre pinto when I was 23. So you should be ok
Sera
Stuart_B
posted on 29/1/10 at 07:20 PM Reply With Quote
cheers david, have not cheecked this thread for a while.
if youa re intreasted in do it i have it for sale for £700 buys you every think listed here
stuart
Stuart_B
posted on 6/3/10 at 06:41 PM Reply With Quote
the duratec is now sold, waiting to be picked up.
stuart
<<  1    2  >>
