richwill
| posted on 26/10/09 at 11:17 AM |
Plumbing layout for pinto
I am looking to sort out my cooling system over the winter as i have had a couple of leaks and problems since i got it on the road. I have pinto with
polo rad and was hoping some of you had photos showing how you have routed your pipes. Is it worth using silicone pipes or do i stick with standard
rubber.
speedyxjs
| posted on 26/10/09 at 11:25 AM |
Quick search came up with this
marshall
| posted on 26/10/09 at 11:26 AM |
hope this helps:
marshall
| posted on 26/10/09 at 11:33 AM |
http://www.cate1.co.uk/ go into build then into engine/gearbox and you will see a bigger picture there hope it helps...
paul the 6th
| posted on 26/10/09 at 11:45 AM |
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
richwill
| posted on 26/10/09 at 12:19 PM |
I have the routing sorted but was looking for ideas of how to make the whole set up look neat and tidy.
| posted on 26/10/09 at 03:25 PM |
Silicone is not worth it IMHO, standard rubber is more than adequate.
Using sections of ally pipe can make things look neater and I've also seen a few cars with 15mm copper pipe used to good effect (painted black).
richwill
| posted on 26/10/09 at 04:01 PM |
i have used some copper pipe on mine and may do the same but spend a little more time in mounting it better and painting it.
I just was not happy with the way it was done but i can improve it quite easily i think.
RichardK
| posted on 26/10/09 at 05:17 PM |
The bruise runs cool as a cucumber with this layout
Rich
Gallery updated 11/01/2011
