<<  1    2    3  >>
Author: Subject: Is mid engine really better?
Ratman
posted on 12/3/10 at 07:40 AM Reply With Quote
I guess, when I started this thread, I had hoped that someone would have some actual hard evidence comparing like with like. In UK I think there are some kit manufacturers who make both front engine and midi versions of cars that are designed and built with very similar concepts and perhaps with identical engines. Then (this is stretching things a bit) maybe they have tested them at track days on the same track and can pass on their experiences. My own experience is pretty much just one short wheelbase (2100mm) midi with 66% weight on the rear wheels. This gives a real advantage off the line and very responsive handling, but it is twitchy and spins do happen. Building again I think I would make the wheelbase longer, and if you are doing this, then it must be six of one and half a dozen of the other for front or mid engine. As soon as the straights get to be a decent length then the biggest difference is probably aerodynamics, and a midi can generally be built lower because the driver doesn't need to be able to look over the engine. I think this is really what caused the shift in the early sixties with F1. All up, I think mid engine is more entertaining, and that's what it is all about..
Here's one of my spins.. What I think happens is that although the midi tends to more likely to spin, it is more likely to stay on the road when it does it. Watching Porsche races on TV, the same seems to happen with them.
http://www.youtube.com/watch?v=UkKSIFUctPc
iank
posted on 12/3/10 at 07:53 AM Reply With Quote
I think that video demonstrates why reverse is now required for IVA. Nose first into a cliff on a blind bend wouldn't be a good place with other traffic around.
Back on subject, I think I probably agree with the aerodynamic argument for single seaters, which seems pretty logical with 20:20 hindsight. Also running a propshaft to the back past the driver requires a wider car in that environment.
Anonymous
cymtriks
posted on 20/3/10 at 11:16 PM Reply With Quote
Originally posted by Alan B
Originally posted by Doug68
Originally posted by Ivan
Cymtrics has raised a vital point about keeping the COG low and the problems with modern FWD drive engines where COG plays a secondary consideration in design
This arguement is good in theory, but then you need to explain the Lotus Elise.
Beat me to it Doug....I'd forgotten just how s**t the Elise was..........could it be better with lower CoG...sure, but we are taking road cars and the Elise aint too shabby......
But we will never know two impotant bits of information:
1) would a front engined Elise (if a suitable drivetrain had been available to lotus) have been just as good or better?
2) how much better would the Elise have been if Lotus had managed to source a purpose designed (i.e. lower CoG) drivetrain?
Saying the Elise makes me wrong is nonsense. You could just as well say that road tests in favour of the MX5 over the MGF prove that front engined is better.
I suspect that as long as a FWD driveline with the typical higher CoG is used then the advantages are very small or possibly not there at all.
Doug68
posted on 20/3/10 at 11:49 PM Reply With Quote
Examples please.
I've looked at Toyota's and a few others and I'm not finding engines on top of transmission's they're next to them as per this Mitsubishi one... Rescued attachment Box.jpg
Doug. 1TG
Sports Car Builders WA
kb58
posted on 21/3/10 at 02:27 AM Reply With Quote
Examples please.
Agreed, much like the Hondas. What are some modern examples of high-CG FWD drivetrains that render them unusable as a group? I don't see any.
[Edited on 3/21/10 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Doug68
posted on 21/3/10 at 03:45 AM Reply With Quote
Ok so how about we clear this up with some dimensions?
Using the bottom of the chassis for reference so to take ride height out of the equation.
For my longitudinally mounted V8 I get the following dimensions from underside of chassis to...
1. CL Crank height. 225mm
2. Top of cam cover height. 595mm
Also the fuel tank is typically 40kg of weight or more and compared to a 7 it seams to be very easy to get the fuel tank in a middy in a better location so from underside of chassis to...
3. Underside of fuel tank 28mm
4. Rough fore aft distance of CG of tank to CG of car. 0mm the CG of the car is inside the fuel tank.
So what do other peoples cars measure and how do the number above compare with a 7?
(CG measurements taken from my CAD model which has proven accurate to date)
[Edited on 21/3/10 by Doug68]
Doug. 1TG
kb58
posted on 21/3/10 at 05:18 AM Reply With Quote
I'm not sure how useful this'll be because it depends if the builder is fine with the oil pan hanging down below the frame rails. I'm not, so I'll come up with one number, but if another builder's fine with 75mm ground clearance, he'll get a much "better" number. Never mind the pan may get removed by a speedbump.
cymtriks
posted on 21/3/10 at 01:10 PM Reply With Quote
Examples please.
Your photo actually shows the engine crank to be several inches higher than the axles.
On a typical FWD the engine crank is a bit forwards and a bit upwards from the axle line.
This is largely to fit in crumple zones, emissions stuff and manifolds. The modern FWD car tends towards tall and narrow engines.
Now look at a purpose designed transaxle. Often they are inverted (axle above engine input) which, with a small bell housing and low sump, can put the CoG much lower. There are also transverse gearboxes available for longitudinal engines (as on the McLaren F1) which also put the CoG lower.
I suspect that we are trying to compare very similar numbers here and that choosing specific cars could be very misleading. The differences between one manufactures list of priorities and parts bin compared to those of another manufacturer are probably far greater than the differences that we are discussing.
kb58
posted on 21/3/10 at 04:05 PM Reply With Quote
But virtually no one uses purpose-designed drivetrains for a Locost/middie street car. Most builders don't have formula car budgets.
In a middie, tyre diameter dictates nearly everything since it defines axle alignment. Since we use street tires and not low-profile racing slicks, tyre centerline (and therefore the axles) end up about where we want. As long as ground clearance of ~4" is acceptable for a street car, modern FWD drivetrains work just great.
MakeEverything
posted on 21/3/10 at 08:07 PM Reply With Quote
Mine uses a renault Transaxle, which has aproximately 30 degree angle of the driveshafts. It was fixed to a renault engine which was in line (as per the original car) and is soon to have the cosworth engine mounted the same way.
Personally, i think the car is very well balanced, and the paperwork at SVA (at the time it was done) said that the weight distribution was 55% to the rear from memory - Almost a perfect balance.
The car is noisy, as the exhausts and the engine are only about 6" from the back of your head, behind a flimsy firewall. I like it, its like russian roulette with pistons rather than bullets!
If this post is out of context, its because i got bored with some of the detail of the above, and thought id post anyway!!
Kindest Regards,
Richard.
Doug68
posted on 22/3/10 at 06:23 AM Reply With Quote
The inverted units you refer to are Porsche G50 units which are way expensive. A lot of people myself included use Audi or Renault units which are not run inverted. Hence the limiting factor on how low you can go is the bottom of the diff.
Also to run a low sump you're basically going to have to go dry sump, so to take advantage of the potentially much lower CG your going to have to spend serious money.
You'll find most GT40's et all are not running dry sumps. On my car the sump protrudes maybe 1/4" beyond the bottom of the chassis, but its the diff really thats stopping me from going lower.
The driveshaft angles at normal ride height are ~7 degrees which is fine IMHO.
Doug. 1TG
<<  1    2    3  >>
