Author: Subject: Does anyone know where i can get one of these ? (BEC Gear Lever)
Tris
posted on 10/5/10 at 01:02 PM Reply With Quote
Afternoon all,
Does anyone know where i can get one of these from ?
Its the Gear Lever adapter that i am after, which fits on to the splined gearbox output shaft on the ZX-12/ZX-9.
Apparently a guy on here (pathfinder) used to manufacture these but has long since dropped of this forum. Anyone know where i can get one from ?
Shiny Gearlever
Shiny Gearlever
Tris
posted on 10/5/10 at 01:08 PM Reply With Quote
I got one from the bike shop scrap bin from a GPZ500. A lot of bikes use the same spline.
tony-devon
posted on 10/5/10 at 01:09 PM Reply With Quote
sorry to ask the obvious, but why cant you use the bike one and modify that?
take the splined/clamp portion, then weld the longer piece that you require to that?
failing that try having a search round the breakers, source the splined shaft, then make your own lever, drill hole, lube and hammer the splined portion through, drill, tap and then split with hacksaw to form the clamp?
heavy is good, heavy is reliable, and if it breaks, hit them with it
posted on 10/5/10 at 01:11 PM Reply With Quote
As above, why not just modify the original? Honda very kindly use a threaded splined thingy on the ST1100 so it was dead easy to do (especially cos I got my brother to do it ).
eznfrank
posted on 10/5/10 at 01:21 PM Reply With Quote
MK sold me mine for a ZX12, just came with their standard BEC shifter kit.
Tris
posted on 10/5/10 at 02:08 PM Reply With Quote
Yes, i could modify my original but i liked the look of the shiny machined item
dazzx10r
posted on 10/5/10 at 02:09 PM Reply With Quote
most of the kawasaki arm are the same, i've used a zxr400 arm on my zx10r motor. Try Blacks bike shop they break loads of bikes on ebay.
40inches
posted on 10/5/10 at 02:14 PM Reply With Quote
Originally posted by Tris
Afternoon all,
Shiny Gearlever
Shiny Gearlever
Tris
OY! that's my photo could have asked me where I got mine from Take your pick from HERE
Tris
posted on 10/5/10 at 02:27 PM Reply With Quote
Fantastic, thanks for all the help - one Pit Bike Gear Lever making its way from Bangkok (via ebay for all of £6
hobbsy
posted on 10/5/10 at 03:32 PM Reply With Quote
Careful I had a cheap gear lever similar to these thrown in with a Honda Chaly I had a while back. It was made of cheese and bent to the point of being unusable within about 3 gear changes.
bi22le
posted on 10/5/10 at 05:41 PM Reply With Quote
Cheesey gear lever?
I bet it smelt good when the engine was hot!
Sorry im really hungry and am waiting for SWMBO to get home before I start the cooking!!
Please read my ring story:
Steve Hignett
posted on 10/5/10 at 05:44 PM Reply With Quote
Do yourself a favour and get a steel one so that when your ali (chocolate) one breaks you can replace it with one that works!
Andy off of AB Performance does them for a good price...
40inches
posted on 10/5/10 at 06:37 PM Reply With Quote
The one in the photo is steel.
[Edited on 10-5-10 by 40inches]
