<<  1    2  >>
Author: Subject: Suspension geometry - I'm Confused!
Brommers
posted on 18/5/10 at 11:32 AM Reply With Quote
Originally posted by Steve Hignett
I assume that the people (FROSTY and Brommers) that are stating that toe out is the only way to go, have bothered to check that the components that are being used are the same???
Because (just for example) If toe out was preferred on Cortina uprights, but toe in preferred on Sierra, and someone was to stupidly state that it HAS TO BE THIS WAY etc. Then I would see that as quite irresponsible and potentially dagerous in itself...
Mind you, this is just my humble opinion, you could well have checked these things, and I should prob keep my nose out.................
Not quite what induces you to make that assumption. In fact, if you actually read what I've posted, at no point have I said that 'toe out is the only way to go' or anything to that effect. I'll let you re-read the thread before offering your apology for misquoting me.
As you correctly point out, the right set up for each car, and each driver, will be different. Personally, I like my cars (Sylva designs with cut-down Escort Mk2 front struts as uprights) to be either parallel or have a touch of toe-out. I've tried setting them up with toe-in instead, and I don't like the way they handle as a result since the turn-in isn't as good.
On other cars, toe-out won't produce good results, and some people who've tried my cars don't like the set-up I use. Chacun a son gout, as they say.
However, what is deeply unhelpful to all concerned is generalised and frankly incorrect statements like 'toe-out on a road car is lethal' which is patently and demonstrably wrong. As you correctly note in your later post, generalised statements of this nature are 'stupid'. A point which my post was trying to make.
procomp
posted on 18/5/10 at 01:46 PM Reply With Quote
Hi
Camber castor effect. If you have poor control of the camber. You'll not be getting the best from your castor. Static camber - camber gain - the amount of camber controlled by castor. It all has an effect on the feel, feed back and stability.
Cheers Matt
whitestu
posted on 19/5/10 at 08:40 AM Reply With Quote
Well, I'll be having a go at getting some self centreing and feel, so hopefully the non adjustable bits of Indy geometry aren't too crap to prevent me making some worthwhile improvements.
Stu
<<  1    2  >>
