Author: Subject: MT 75 Info needed
posted on 15/6/10 at 12:39 PM Reply With Quote
MT 75 Info needed
THIS LISTING on eblag says fits 1990~2000.
Does that mean it will have the standard 4 banger bellhousing pattern the same as a type 9?
Looking for something like this to go behind a zetec.
snapper
posted on 15/6/10 at 12:44 PM Reply With Quote
The bellhousing looks huge and the gearlever is in the wrong place
I eat to survive
I drink to forget
flak monkey
posted on 15/6/10 at 12:45 PM Reply With Quote
Should do yes.
Sera
http://www.motosera.com
r1_pete
posted on 15/6/10 at 12:55 PM Reply With Quote
It will probably fit, but the ratios will be awefull in a car.
stevec
posted on 15/6/10 at 01:03 PM Reply With Quote
Looks very much like a Transit 2.5 Diesel box.
posted on 15/6/10 at 01:15 PM Reply With Quote
OK, what I'm looking for is a short (shorter than type 9) to go behind a zetec. Direct bolt up required.
Its so I have enough room to hang a 410 transfer box with a short (4"~6" prop off the back... then the props go to Range Rover axles.
UNLESS... I can get a LT77 with landrover transfer box attached then it will be T16 turbo powered
Vindi_andy
posted on 15/6/10 at 01:50 PM Reply With Quote
Got a spare MT75 you can have to play with.
Not sure where in the UK you are but Im in the midlands
posted on 15/6/10 at 02:05 PM Reply With Quote
Cheers Andy, going to Newark by any chance?
smac
posted on 15/6/10 at 05:18 PM Reply With Quote
I got a transit gearbox you can have if you like. Save me falling over it.
Vindi_andy
posted on 15/6/10 at 05:45 PM Reply With Quote
forgot to mention its a car MT75. Just been and measured it and its approx 620mm from bell housing to output flange.
Yes I am going to newark but only Sunday (wife refuses to camp over) so let me know if this is ok and Ill find a way to fit it in tango.
How does £20 sound.
paul@firstmotion
posted on 15/6/10 at 08:59 PM Reply With Quote
MT75
The MT75 in the listing is for a transit diesel hence the large bell housing and position of the gearlever no good for fitting to 4 pot petrol pinto or zetec!!
