liam.mccaffrey
posted on 26/10/10 at 12:54 PM |
Bolted outer Stub Axles
Does any one know any cars which have bolted outer stub axles like the sierra?
Build Blog
Build Photo Album
minitici
posted on 26/10/10 at 01:06 PM |
Old VW beetles
posted on 26/10/10 at 01:38 PM |
Do you mean as in using Lobro joints with bolt on ends...?
If so then IIRC most VAG cars do obviously FWD in the main though.
Might be worth looking at driveshafts first to see what cars are fitted with Lobros?
v8kid
posted on 26/10/10 at 02:20 PM |
Cortina? As in the grass track guys.
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
grassracer
posted on 26/10/10 at 02:35 PM |
If you mean that they bolt the bearing housing to the rest of the rear arm like the back of a Sierra there ain't many.
Only ones I've found are Volvo s40 or early Fiat Panda, obviously both front wheel drive though
posted on 26/10/10 at 02:38 PM |
Sometimes called in the books a "Live Stub Axle". The Sierra was almost unique among RWD production cars in this respect this is because
the front end geometry was designed from the start to allow a minimum change 4wd version.
You can convert any FWD set up by simply gutting the CV joint of the inner spyder, balls and cage.
posted on 26/10/10 at 02:41 PM |
Really confused now, I had assumed you were asking about the front.
The Sierra/Granada Scorpio bolt on rear set is also pretty unique.
posted on 26/10/10 at 02:51 PM |
help us out here Liam...?
Just and F or an R would do
interestedparty
posted on 26/10/10 at 02:57 PM |
My guess is he means the bolt on rear hub carriers, most cars don't have anything like that. BMW for instance the bearings are pressed into the
trailing arm direct.
liam.mccaffrey
posted on 26/10/10 at 03:10 PM |
What I am looking for is a cost effective way to make my mx5 outer cv joint serviceable. As it is I have to have a custom shaft made to go from my
volvo 850 inner CVs to mx5 outer CVs.
My problem is that the outer mx5 CV isn't designed to be removed once on as it has a blind snap ring. It is possible to remove it but its a
PITA and I wouldn't want to try it whilst its on the car.
I don't really want to put my lovely new expensive custom shafts into a place they're not designed to out from.
My bright ideas to date are as follows, some better than others!
Find a bolted stub axle bigger than the mx5s and have it machined and re-heat treated.
Find a bolted stub axle and have the mx5 hubs broached out to match
Find a bolted stub axle (or a removable CV joint) that magically fits the mx5 hub dimensions.
Have a different vehicles hub and stub axle pair machined to suit the upright (like the V8 miata fellas do)
Don't use mx5 uprights at the back.
Custom made stub axles.
An obvious solution I haven't mentioned but someone will think of.
Any ideas
[Edited on 26/10/10 by liam.mccaffrey]
Build Blog
Build Photo Album
3GEComponents
posted on 26/10/10 at 06:05 PM |
Nissan 200SX?
Kind regards
John
liam.mccaffrey
posted on 27/10/10 at 12:41 PM |
Ive just had an idea, its mad but it just might work
Build Blog
Build Photo Album
Volvorsport
posted on 27/10/10 at 10:21 PM |
have a closer look at your volvo front suspension .
they have bolted bearing carriers , the axle is teh cv joint poking through it .
do a search on ebay , you can find new bearing carriers for XC90 also .
www.dbsmotorsport.co.uk
getting dirty under a bus
