ShaunB
posted on 30/10/10 at 05:56 PM |
Xflow 1300 vs 1300 GT - different head castings?
Can any tell me if the larger valved head fitted to the 1300GT xflow is just a standard 1300 head with larger valves/seats fitted or is it a different
casting/part number?
I'm building a spare race engine, but the spare GT head I have has been ported and hence not allowed under the Locost regulations.
Shaun.
D Beddows
posted on 30/10/10 at 08:27 PM |
The only different crossflow head (ie with bigger valves) is a 1600 GT - a 1300 GT head is bog standard. I used to build 750MC Locost engines so know
1300 xflows inside out
panichat
posted on 31/10/10 at 10:19 AM |
Interesting...
What are the differences between 1300 and 1300GT crossflows then?
Carb and inlet manifold, what else?
Dave
posted on 31/10/10 at 10:46 AM |
The GT has a longer duration cam IIRC.
ShaunB
posted on 31/10/10 at 12:36 PM |
quote: The only different crossflow head (ie with bigger valves) is a 1600 GT - a 1300 GT head is bog standard. I used to build 750MC Locost engines
so know 1300 xflows inside out
Thanks for that info, I knew the 1600GT head was different, so assumed the 1300 was too. So I just need to
get hold of an unmodified 1300 head. Anyone got one they no longer need?
quote: What are the differences between 1300 and 1300GT crossflows then?
Flywheel was lighter, same weight as the 1100, but with the larger 1300 clutch face.
[Edited on 31/10/10 by ShaunB]
Ivan
posted on 31/10/10 at 02:13 PM |
From recollection going back 40 years the GT heads had a slight bowl in them whilst the standard heads were dead flat.
paulf
posted on 1/11/10 at 10:35 PM |
I have a complete cross flow head left over from when I ran a cross flow, it is complete with rocker shaft and cover and appears to be in good
unmodified condition.If you still require one let me know.
Paul
