Author: Subject: underseal and paint removal on a mini
corrado vr6
posted on 18/2/11 at 08:01 PM Reply With Quote
Hi there, ive got a mini project on the go and im trying to take the underside panels back to bare metal, ive tried paint thinners and a wire brush attachment in a drill which work but is really slow at removing the last layre of paint. Has anyone got any ideas to speed the process up? would parrafin work? Thanks in advance Greg
http://r1indy7.wordpress.com/
Andybarbet
posted on 18/2/11 at 08:06 PM Reply With Quote
I used nitromors and it dissolved it quite well, paint scraper took it off then.
Mind your arms tho cos stings
austin man
posted on 18/2/11 at 08:11 PM Reply With Quote
hot air gun if the tanks removed and a paint scrapper
Benzine
posted on 18/2/11 at 08:28 PM Reply With Quote
These things are awesome for paint removal, not sure what they're called though
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make it moral.
Mark G
posted on 18/2/11 at 09:00 PM Reply With Quote
Heat!
Shogun969
posted on 18/2/11 at 09:32 PM Reply With Quote
Blow lamp and scraper then wire brush, i have done 3 minis back to bare metal on the underside
Badger_McLetcher
posted on 19/2/11 at 12:57 AM Reply With Quote
Yeah +1 for these things. Also can't remember what they're called though I'm afraid :S
If disfunction is a function, then I must be some kind of genius.
MikeR
posted on 19/2/11 at 01:06 AM Reply With Quote
Screwfix seem to call them preparation wheels,
http://www.screwfix.com/prods/83915/Abrasives/Other-Cutting-Grinding/Surface-Preparation/Preparation-Wheel-115mm
I've used the 'drill' based version and will say that whilst they're good in a drill, they do disintegrate quickly when they find edges - they like panels, not corners
(also, if you use them on wood be careful as they did a grove quite easily and mark glass quite nicely!)
posted on 19/2/11 at 09:11 AM Reply With Quote
Get the bulk off with a sharp wood chisel, a bit of heat can help but hot underseal is PAINFUL!
posted on 19/2/11 at 09:19 AM Reply With Quote
Polycarbide wheels, good for stripping the rough stuff without damaging the metal underneath.
ChrisW
posted on 19/2/11 at 11:34 AM Reply With Quote
This might make interesting reading for you: http://locostbuilders.co.uk/viewthread.php?tid=149827
It's a long and horrible job, but you'll get there in the end. I found a wire brush 'cup' for a grinder was good for the big areas and a blow lamp and scraper for the bits that the grinder can't get into. My arms were aching for days but I hope the finished product will be worth the effort.
Chris
