phelpsa
posted on 18/2/11 at 10:06 PM |
Flywheel lightening
Does anyone know of anywhere in the south that can lighten/balance a flywheel. Also, any ideas on how much it might cost?
Cheers, Adam
big_wasa
posted on 18/2/11 at 10:12 PM |
I bought mine from scholar engines
phelpsa
posted on 18/2/11 at 10:16 PM |
This is for a 4age engine btw Scholar engines don't seem to do anything with them but cheers anyway.
Confused but excited.
posted on 18/2/11 at 10:41 PM |
Oh, not an electrical fault then.....
pewe
posted on 18/2/11 at 10:56 PM |
Try Roe Engineering in Fleet. tel 01252613404 - think he's open Sat am.
Cheers, Pewe
phelpsa
posted on 18/2/11 at 10:58 PM |
Took a few seconds but i got there in the end Lightening - to make lighter, Lightning - funny electric stuff in the sky!
phelpsa
posted on 18/2/11 at 10:59 PM |
Cheers, Pewe
Cheers! Will give them a ring.
austin man
posted on 18/2/11 at 11:12 PM |
get the clutch and crank pulley done as well as the are all on the same axis
omega0684
posted on 19/2/11 at 08:56 AM |
just balance the whole bottom end, crank and rods too"
phelpsa
posted on 19/2/11 at 02:17 PM |
I think we're getting a bit carried away here. The last thing i want is to tear the engine apart, just looking to free it up a bit while
i'm changing the clutch!
Garyd
posted on 19/2/11 at 03:03 PM |
Another yes for roe engineering in fleet as they used to do all my machining work for my race car, very helpful and relatively cheap.
pewe
posted on 21/2/11 at 10:28 AM |
Don't know your particular engine but you might like to discuss with Roe whether there are issues with taking the fly-wheel off , skimming and
remounting it in realation to crankshaft balance.
At the very least the flywheel needs to go back onto the crank in the same position (not a prob if it's pegged of course).
HTH.
Cheers, Pewe
phelpsa
posted on 21/2/11 at 01:50 PM |
Well the clutch has just started slipping horrifically, so it doesn't look like i'm going to have time to find another flywheel and have
it lightened before I have to fit a new clutch.
Thanks for the help anyway! Will keep Roe Engineering in mind in case
