Author: Subject: Bradbury jack seals
posted on 21/2/11 at 11:56 AM Reply With Quote
Bradbury jack seals
I have an old trolley jack, a Bradbury Jackette which had a weep so I took it to pieces and found two seals cracked and an O ring split. I would like to replace these but they are not standard sizes and the only option on the net is a Jackette seal kit which is 45.95 + VAT +4.95 p&p. Does anyone know of anywhere I can find just the parts I need? I have tried all the local bearing suppliers and had no luck.
JeffHs
posted on 21/2/11 at 12:26 PM Reply With Quote
There are people about who make custom seals. We needed some for the Hydarulic flap actuator on the Auster. My mate got them made in Sheffield. I'll try to find the company name - they weren't silly money if I remember.
balidey
posted on 21/2/11 at 12:33 PM Reply With Quote
Someone like these people will almost certainly have something close to what you want.
http://www.hallite.com/
Dutch bears have terrible skin due to their clogged paws
paulf
posted on 21/2/11 at 12:39 PM Reply With Quote
I have a Bradbury jackette and it also developed a leak,I kept refilling it for a year or 2 but eventually it got to bad to use.
I stripped it and found the main cause of the leak was the plunger seal, not knowing exactly what it was like when new i just went to a local hydraulics supplier and got a couple of similar sized O rings .The nearest size was an imperial one with a thick section and after stretching it a bit to fit it now works perfectly with no leaks.
Paul
posted on 21/2/11 at 12:52 PM Reply With Quote
That's the ones on the plunger seal, one's a thick O ring and apparently the other is a U ring. There's a big O ring in the end of the ram section that is a bit iffy as well so I want to replace that as well so if O rings will do it I'll look for some of those. All the ones I've found so far just disappear in the slots as they are too thin.
Dingz
posted on 21/2/11 at 01:09 PM Reply With Quote
Can you carefully measure the seals and sketch of them, send me a U2U with the info and I will try to help.
went on and on.
posted on 21/2/11 at 01:13 PM Reply With Quote
I am on my way out to the shed to measure them, here's hoping thanks.
paulf
posted on 21/2/11 at 01:47 PM Reply With Quote
I replaced them both with O rings if I remember correctly, it did take a bit of searching through boxes of O rings to find some near the correct section, mine has been fine since and even though they may not be the exact replacement they are not really under high stress compared to proper hydraulics.
Paul
