Author: Subject: DIY car lift
smart51
posted on 25/6/11 at 02:03 PM Reply With Quote
DIY car lift
There isn't much clearance under the car and even a trolley jack and axle stands don't make enough room to work under it. Proper car lifts cost big money but I'm willing to have a go and make something. What would you suggest I copy, sorry, take inspiration from?
flibble
posted on 25/6/11 at 02:11 PM Reply With Quote
Few ideas on here?
will121
posted on 25/6/11 at 03:02 PM Reply With Quote
Just got my copy of this months PPC mag through post, and they have a review of about 6 different ones should be in shops Thursday
Fred W B
posted on 25/6/11 at 03:26 PM Reply With Quote
If its for a 7 or other light car (with a flat bottom) have a look at the lifts used for sevicing motorcycles, basically a flat table on 2 hinged frames that can be raised by a jack
Fred W B
mangogrooveworkshop
posted on 25/6/11 at 03:28 PM Reply With Quote
There's a place that does second hand stuff for not much money
Cant remember the name of it
Dave Ashurst
posted on 25/6/11 at 03:52 PM Reply With Quote
Would it be cheaper to make or to buy something like this ?
Dave Ashurst
posted on 25/6/11 at 03:58 PM Reply With Quote
or this:
Dave Ashurst
posted on 25/6/11 at 04:10 PM Reply With Quote
Or a pair of big ramps for £25 here
It would be a challenge to make them yourself cheaper!
smart51
posted on 25/6/11 at 04:30 PM Reply With Quote
Nice suggestions. The car is too low at the front for ramps but the big long ones with trolley jacks are interesting. I was thinking of cannibalising a trolley jack for the mechanism and fitting it to something that will raise the whole car and by a decent height.
Chaddy
posted on 25/6/11 at 04:53 PM Reply With Quote
I use the two ton engine crane i bought to put the engine in, made a lifting beam from old angle iron, use web straps on the roll bar. i can then lift it onto stands at a good working hight.
jacko
posted on 25/6/11 at 05:11 PM Reply With Quote
Car Display Ramps Van Stands Automotive SeeSaw Tilting | eBay UK
How about this
Jacko
907
posted on 25/6/11 at 05:26 PM Reply With Quote
I made some stands a while ago that I use with the ramps off my trailer but seeing the ones in the above link
has got me thinking.
long ramps
long ramps
If I made something to raise the end and could hook on a sort of mini ramp I then could get the jack under much easier.
Cheers Dave.
Paul G
macc man
posted on 25/6/11 at 06:34 PM Reply With Quote
I use an alloyracing jack from machine mart. I goes under a treat and then use axle stands for safety. Be carefull making a diy system as it could fail on you.
v8kid
posted on 25/6/11 at 07:17 PM Reply With Quote
+1
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
mark chandler
posted on 25/6/11 at 07:45 PM Reply With Quote
How about this ? Electric fork lift | eBay UK
Extend the arms and bolt to the garage wall
[Edited on 25/6/11 by mark chandler]
pdm
posted on 25/6/11 at 07:50 PM Reply With Quote
There are tilting ones you can get, one guy on a MX5 forum I go on had one. It lifted to a good height but also tilted - sounded quite expensive to buy but maybe a worm drive for the tilting bit might work (somehow)
hughpinder
posted on 27/6/11 at 08:09 AM Reply With Quote
How about 'tube stands' like the rally boys use - you will need to weld a tube to your chassis (in rally cars its a tube welded into the sills) and the stands have a 'pin' that slides into the tube. They don't look very substantial, but my next door neighbour has his subaru rally car stood up on them so they'll certainly be strong enough for a seven.
I've put a picture in my archive cos I can't remember how to stick it in the message!
Regards
Hugh
HowardB
posted on 27/6/11 at 08:28 AM Reply With Quote
I knocked this up the other day, goes under a treat, and levers enough access to then get a "proper" jack under. drawings available by u2u
locost low jack
locost low jack
Howard
jacko
posted on 28/6/11 at 06:12 PM Reply With Quote
http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=157532
Steve Hignett
posted on 28/6/11 at 06:46 PM Reply With Quote
locost low jack
locost low jack
I have a DIY set of similar to the above, that I made a while ago, for sale if anyone is interested?
(Don't know what they're worth, but I've been out of work nearly a month now and still not a snifter of work, so trying to sell everything I've got!)
