Author: Subject: Pinto 36-1 trigger wheel
po79
posted on 25/8/11 at 04:27 PM Reply With Quote
Hi all,
I'm after one of the above again, I did have someone from here offer to make me one but he hasn't got back to me so looking again.
I don't mind if its second hand or newly made so long as it saves me a few quid.
Many thanks,
Po.
mcerd1
posted on 25/8/11 at 05:02 PM Reply With Quote
what about these if 'off the shelf' will do ?
http://www.trigger-wheels.com/store/contents/en-uk/d5.html
norfolkluego
posted on 25/8/11 at 06:00 PM Reply With Quote
I've got one you can have for mates rates if it's the right size
po79
posted on 25/8/11 at 07:45 PM Reply With Quote
Hi norfolkluego, thats appreciated! I shall have a measure up and give you the dimensions. fingers crossed!!
Hi mcerd1, when I said new I ment if some one was willing to make one for me, I personally think trigger wheels are a little bit on the pricey side. Still if all else fails....
Cheers guys,
Po.
snapper
posted on 25/8/11 at 08:33 PM Reply With Quote
I also have a spare secondhand for £10
I eat to survive
I drink to forget
po79
posted on 26/8/11 at 05:21 PM Reply With Quote
I just measured the crank pulleys outside diameter it was a bit tricky to get to but sure I got it right.
Its 117mm or 11cm 7mm or if its going to be a weld on type the trigger wheel will need this as its inside diameter or if its a universal one the outside diameter will need to be larger than this.
Let me know guys.
Many thanks,
Po.
mcerd1
posted on 27/8/11 at 01:50 PM Reply With Quote
most pulleys are cast - welding onto them isn't always the best idea...
(I've heard of trigger wheels flying off while at the rolling road etc...)
po79
posted on 27/8/11 at 05:20 PM Reply With Quote
I'd not heard of that before, good to know!
I was going to get my dad to weld it (if thats the type I get) as he's a retired coded welder and still has all the gear. so wasn't really bothered about the pulley being cast, perhaps the ones that have came off were done by someone without the correct skills/knowledge.
I kind of prefered the idea of weld on trigger wheels as I don't overly like the idea of bolt on ones as I would loose upto 6mm of thread on the crank bolt.
Po.
mcerd1
posted on 28/8/11 at 07:53 PM Reply With Quote
Originally posted by po79 perhaps the ones that have came off were done by someone without the correct skills/knowledge.
probably, but bolting still going to be easier IMHO
you'll lose a bit more than just the trigger wheel thinkness on the bolt length as the bolts are set back into the pulleys a bit, so you normaly need a spacer between the trigger wheel and the pulley - easily sorted with a longer bolt though
or if your pulley is a later type with the small tapped holes you could use them to mount it
or if you've got a handy lathe you could do something like what I did
[Edited on 28/8/2011 by mcerd1]
