nre
posted on 2/10/12 at 09:01 AM |
WTD: Someone to TIG weld lambda boss onto my exhaust? - Near Warwick
Anyone near to Warwick who can TIG a lambda boss onto my exhaust (section is fairly small and removed from the car).
Beer tokens available!
It's to replace the previous one, bung has now completely seized in place:
Cheers!
[Edited on 2/10/12 by nre]
Sylva Mojo Zetec on GSXR750 throttle bodies...
www.mymojo.co.uk - Facebook feed
JPSC Forum - A dedicated forum for discussion on all things relating to Jeremy Phillips designed cars
Including the Star, Leader, Striker, Phoenix, Fury, Jester, Stylus, Mojo, Riot, J15 & Vectis
matt_gsxr
posted on 2/10/12 at 09:10 AM |
I am no expert, but why can't you just MIG it (or maybe you don't have MIG).
I've found stainless wire a godsend for repairing saucepans and other kitchen bits where the spot welds fail.
Hence justifying the cost of the welder!
nre
posted on 2/10/12 at 09:14 AM |
Don't have any welding facilities myself, got it TIGed last time round so seemed sensible to do the same again...
matt_gsxr
posted on 2/10/12 at 09:56 AM |
That is a good reason not to DIY
Agriv8
posted on 2/10/12 at 10:21 AM |
have you tried giving the old one a good belt with a hammer strait on the face of the bung ( biggest hammer you dare that wont crush the tube )?
it may crack the sezure and enable you to release !
ATB agriv8
blakep82
posted on 2/10/12 at 10:33 AM |
ATB agriv8
or a blow torch to heat the pipe (but try to avoid the bung) as stainless expands a fair bit more than mild steel, might be enough to help lever it
out?
________________________
nre
posted on 2/10/12 at 10:47 AM |
Tried just about every trick I could think of including blow torch and brute force, but it wouldn't budge. Then proceeded to try drilling out
and smashing out the remnants but it has well and truly fused into a single piece! Decided it was time to admit defeat...!
Chippy
posted on 2/10/12 at 12:23 PM |
When I had mine done I went to a local welding place, and was well pleased, not only with the job but also the small price just £20, plus he did it
while I waited. HTH Ray
tilly819
posted on 2/10/12 at 01:27 PM |
is that a S/S bung in a S/S boss??
You want to use a mild steel bung in a S/S boss. never had any problems doing it this way. I belive it is becuse of the differing thermal expansion
properties of stainless vs mild.
worth having the bung black phosphated too so is has some elemant of corrosion protection.
hope this helps for future
tilly
[Edited on 2/10/12 by tilly819]
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
nre
posted on 2/10/12 at 01:29 PM |
tilly
Not sure what the original one was, replacement is a SS boss with mild steel bung as recommended :-)
Thanks!
motorcycle_mayhem
posted on 2/10/12 at 05:52 PM |
If you believe Lincoln to be near Warwick, then I'll gladly do it for you if you bring a few bottles of Duck Soup.
This weekend isn't possible (I'm on a distant track), but if there's no hurry drop me line...
tilly819
posted on 2/10/12 at 06:06 PM |
I can do it if you are coming past melton mowbray over a weekend or of a evening
tilly
