Author: Subject: Alternator wiring question. Daihatsu Denso
jon200
posted on 4/2/13 at 03:50 PM Reply With Quote
What needs to go where with this so that I have a working battery light. Obviously I have the large +ve terminal to the battery but what about the other ones?
What goes to IG and what goes to L? I'm guessing IG is ignition live but what about the L and where does the bulb go?
big-vee-twin
posted on 4/2/13 at 03:57 PM Reply With Quote
[img] Description
[/img]
http://www.triangleltd.com
Benzine
posted on 4/2/13 at 03:59 PM Reply With Quote
Any use? Taken from a thread I made here
Tiger Super Six
posted on 4/2/13 at 04:01 PM Reply With Quote
Originally posted by big-vee-twin
[img] Description
[/img]
This is your friend - just figure out which you have, or post a pic of the alternator terminals.
Mark
Tiger Avon
jon200
posted on 4/2/13 at 07:03 PM Reply With Quote
So L goes to a 2-3w lamp to earth?
Dusty
posted on 4/2/13 at 10:42 PM Reply With Quote
L to ignition lamp to ignition live, not earth.
Assuming the ign light is a proper bulb, not an LED.
jon200
posted on 5/2/13 at 01:22 AM Reply With Quote
I though IG was for a switched live from the ignition? or does L need to be permanant live?
jon200
posted on 10/2/13 at 10:21 PM Reply With Quote
So I need a switched live to both then? Switched to IG and a switched to L via a lamp?
AndyW
posted on 11/2/13 at 08:36 AM Reply With Quote
IG is a switched 12v (that helps energise the alternator)
L is your output to ign warning light.
Thats how mine was wired and works fine
loggyboy
posted on 11/2/13 at 08:45 AM Reply With Quote
Yes, exactly that.
Mistral Motorsport
whitestu
posted on 11/2/13 at 11:25 AM Reply With Quote
The ignition lights don't always work as you might think.
Mine is the same as the type 4 diagram and all the L does is outputs a signal. It didn't even give enough currrent to light an LED. I used the signal to switch a diode, which then then acted as a relaye to supply a 12v feed to the ignition light.
jon200
posted on 11/2/13 at 06:28 PM Reply With Quote
cool cheers chaps.
MkIndy7
posted on 11/2/13 at 08:57 PM Reply With Quote
Isin't the 12v +ve feed to the alternator light supoosed to come from the Ignition live circuit.
The Alternator is then provides the -ve when at rest and then +ve when its charging.
Thus the light illuminates when the ignition is sritched on but is then is fed with +12v from both sides when the alternator is working n thus doesnt light up.
All this relays and Diodes sounds rather complicated
