whpracer
posted on 3/10/04 at 09:41 PM |
witch shocks are good ?
am , just starting of making my one 7 look a like chassis , but i stil don't no witch shocks i should buy . does anyone has any suggestions ?
i looked at SPAX, AVO , GAZ , but they have al the same adjustments and generaly the same price .
maybe some of you has experince between different type of shocks
posted on 3/10/04 at 10:29 PM |
the absolute cheapest are zeemerides, as far as i know. These are available from lolocost. Next up is the shocks supplied by darren at GTS. these are
designed around an average 7 replica, so will suit most cars. the ride height is adjustable, but the dampers are not. the damper are set up for the
springs they come with, so if you change the springs the dampers cant be adjusted to match. Not the end of the world if you leave them with the
standard springs. Darren charges £220 i think.
above these two are the fully adjustable ones, basically you pay more to get them adjustable.
I am using darrens shocks, they have worked well for me so far.
dozracing
posted on 4/10/04 at 04:32 AM |
GTS shocks are available from stock now. Buy online at www.gtstuning.co.uk
blueshift
posted on 5/10/04 at 12:15 AM |
I'm another happy GTS customer.
I'll be even happier when the rest of our order turns up..
jimgiblett
posted on 5/10/04 at 12:15 PM |
Alot of the BEC guys are raving about how good the new ali protech shocks are. And if I was to build again I would certainly consider them. My Avo
shocks are working well but not that lightweight being steel bodied.
One point to remember is that a bike engined car will be significantly lighter than a car engined equivalent and the shocks and springs should be
chosen accordingly.
My 2p worth
Jim
the x man
posted on 8/10/04 at 07:10 PM |
www.icondevs.co.uk do a nice line of stuff for kits.. try them...
