<<  1    2  >>
Author: Subject: CAN bus on a locost
v8kid
posted on 23/9/13 at 07:47 AM Reply With Quote
Originally posted by Texan
As we use newer & newer donor vehicles I see Can Bus becoming more of a reality for all of us PLUS I see it as a solution to all the problematic cut down wiring harnesses so I'm definitely interested in learning more about them and seeing any aftermarket alternatives.
Even without newer donors I see this as a way to lighten & simplify, things Colin would definitely have appreciated.
Unless I'm totally misunderstanding exactly how it works, which wouldn't surprise me, it doesn't seem to be all that difficult a concept.
You are right the concept is quite simple its the implementation that gets complicated! There are so many interacting systems on a saloon that it is difficult keeping track of them all - particularly safety systems such as brakes, air bags etc.
However for a locost, or a boat, these complications do not arise and provided robust cheap modules can be sourced it would be a winner. However so far I've found you can get cheap, reliable or easy to program choose any two .
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Texan
posted on 23/9/13 at 02:07 PM Reply With Quote
Doesn't each device on CanBus just use different "frequencies"?
I'd not think we get anywhere near limits of different frequencies on the typical car. As a matter of fact if we did then I don't think the auto manufacturers would be using it.
I drive therefore I am.
<<  1    2  >>
