<<  1    2  >>
Author: Subject: Another hot start problem
r1_pete
posted on 27/7/14 at 06:20 PM Reply With Quote
Originally posted by adithorp
A bigger battery would help, as would a high torque starter but neither are fixing the fault. Back the cranking advance off. If it fixes the problem, job done.
and zero cost......
Sierra
posted on 27/7/14 at 06:30 PM Reply With Quote
Very true, unfortunately I don't have a laptop with the right port.
Reading a lot of posts on this forum it seems a lot of people have had to change to a high torque starter.
r1_pete
posted on 27/7/14 at 06:37 PM Reply With Quote
What do you need a Serial Port?? if so, a USB to Serial adapter based on the Prolific or FTDI chipset will do the job, the cheapo adapters don't seem to work with engine management systems.
adithorp
posted on 27/7/14 at 07:37 PM Reply With Quote
That may be because they ask on here about poor hot starting and get two answers; Retard the ignition from experienced mechanics and put a bigger starter on from others. They then ignore one option.
If you ask how to remove something and some people give you a detailed step by step guide and someone else says get a bigger hammer, which would you do?
http://jpsc.org.uk/forum/
Sierra
posted on 27/7/14 at 09:03 PM Reply With Quote
Haha well put. I'm going to give it a go a set it to 0' and see what happens
Sierra
posted on 30/7/14 at 09:29 PM Reply With Quote
Quick update, I phoned omex on advice on the cranking advance and they explained that the engine isint turning over enough for the ecu to even begin to work. I don't really understand any of it but I went and bought an edge high torque starter and so far so good.
Next step is to take it to the rolling road for a tune up. Options so far are
Power engineering
TTS performance
Northampton motorsport
r1_pete
posted on 31/7/14 at 07:32 AM Reply With Quote
Wow thats some statement from Omex, if the ECU isn't working at cranking speed what is firing the injectors, and sparks??
The ECU has a set of parameters it uses at cranking speed to start the engine, and even before cranking starts e.g. fuel pump prime, you have been seriously mis informed.
<<  1    2  >>
