Author: Subject: overfilled Xflow
Slater
posted on 23/10/14 at 11:04 AM Reply With Quote
overfilled Xflow
Hi
I overfilled my 1600 xflow with oil.............. only by 10mm on the dipstick, will it be OK? or should I drain some out?
Paul Turner
posted on 23/10/14 at 11:07 AM Reply With Quote
Drain some out, its easy, simply remove sump plug.
You don't want the crank thrashing about in the oil, causes frothing, loss of pressure and guess what happens next.
steve m
posted on 23/10/14 at 11:52 AM Reply With Quote
It will leak out all on its own, as its a xflow
But you should take some out, as it will smoke heavily over about 3k
steve
Slater
posted on 23/10/14 at 04:43 PM Reply With Quote
Ok, thanks for the advice guys.
