<<  1    2  >>
Author: Subject: 13" wheels on a roadster
mark chandler
posted on 26/12/14 at 11:33 PM Reply With Quote
My rear bone, same design with a diagonal
Rosco86
posted on 27/12/14 at 03:28 PM Reply With Quote
Yeah, I see what your saying, do you think one diagonal is enough or would a cross be better?
Got a bit more done this morning
davidimurray
posted on 27/12/14 at 10:44 PM Reply With Quote
You're making good progress. In theory one diagonal should be sufficient and doubt it makes a difference to our cars. In theory I suppose you should consider the direction in which the upright is trying to resist and get the members in the correct tension/compression states. In reality we know the standard roadster design is proven (well mine hasn't fallen apart in 1500miles fingers crossed!). Personally I wouldn't both with the tube straight across at the upright end and got for a x-brace as belt and braces(excuse the pun) for little weight penalty . If you think about it, once the bolt is through the rod ends you have effectively put a solid brace across the upright end.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Rosco86
posted on 28/12/14 at 08:20 PM Reply With Quote
Looks good, think this is what I'm going for, thanks for the shot
Rosco86
posted on 28/12/14 at 08:24 PM Reply With Quote
Yeah I see what your saying but I'm going to have the tube across at the upright end as it's just more area around the rod end tube for welding, also I think just one diagonal as like you say it's proven because my first attempt closed in when welding and was hard to open back out, it tells you in the book which way to have them, I think it's outside rear to inside front
<<  1    2  >>
